Old 04-27-2011, 10:00 PM   #1
'65 chevy lover
Replacing upper and lower ball joints
While I'm doing the front brakes on my '65 chevy truck, I'm going to replace the upper and lower ball joints. The rubber on both is split. It appears the upper joint is held in with rivets. I figured I would grind them off flush with the top of the joint and then, drive the rest of it thru. Not shure how the lower ball joint is secured. Is it a press only fit? I don't see a retaining clip any where. Any advice or tips would be greatly appreciated. Did a search on the site and didn't really see much. Thanks in advance.
edit: I checked you tube and there were videos but, for some reason they wouldn't play
Spanky
'65 chevy lover is offline   Reply With Quote
Old 04-27-2011, 10:11 PM   #2
LiLDrumKing3
Re: Replacing upper and lower ball joints
When I did mine a little while back, I believe the lower ball joints were just press fit. The tops I used an air chisel to pop the heads of the rivets and then punched out the rest of it. The new upper ball joints should have bolts that replace the rivets. I don't know if this helps.
p.s. - wear ear protection if you have your head inside the fender well while you are hammering, grinding, or chiseling. I remember my ears hurting quite a bit after air chiseling with my head inside there. Probably wasn't the smartest idea
Jeremy
1965 Chevy c10 Short Stepside
Check out my Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=410658
LiLDrumKing3 is offline   Reply With Quote
Old 04-28-2011, 08:50 AM   #3
'65 chevy lover
Yeah, that helps alot...I guess you use a pickle fork to get the lowers out...is that right?
Thanks,
Spanky
Old 04-28-2011, 09:14 AM   #4
willyp
willyp's Avatar
+1 on what drum king said. grind rivets off and the new ball joints come with bolts. i used a BFH to get the lowers out then used a big socket and a hammer to get the new ones in. i also had the lower control arms off the truck too.
The price of cool aint cheap.
willyp is offline   Reply With Quote
Old 04-28-2011, 06:38 PM   #5
LiLDrumKing3
Thanks,
Spanky
It wasn't a pickle fork, but that probably will work. I believed we used some kind of ball joint puller that was powered by an impact wrench. And I'm pretty sure we used the same tool reversed to get the lower ball joint back in. That was in my highschool shop class, so I don't remember what the tool was called.
Jeremy
Old 04-28-2011, 08:12 PM   #6
towersddg9
towersddg9's Avatar
You can rent a ball joint press from your local AP store, makes the lowers a snap
towersddg9 is offline   Reply With Quote
Old 04-28-2011, 08:38 PM   #7
'65 chevy lover
I got the tops of the rivets ground off but, I'm having a hell of a hard time knocking them thru. Got three on one side about 1/8" down but, can't really seem to get a good swing on the hammer. Should I try to drill them out or, at least part way out? I have an air chisel but, don't think I have a bit that small. Any tips would be greatly appreciated.
Thanks,
Spanky
Old 04-28-2011, 10:32 PM   #8
towersddg9
towersddg9's Avatar
drill em
Old 04-30-2011, 10:27 PM   #9
'65 chevy lover
I did have an air chisel bit with a pointed tip...had the rivets out in about 2 minutes...piece of cake
Old 03-06-2012, 11:56 PM   #10
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
There's talk that upper and lower ball joints are expensive for the 60-62.
Why couldn't we just replace our ball joints with newer model ball joints?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 03-09-2012, 11:46 AM   #11
thebacon
I've been looking at them and 60-62 is ~40 bucks, and 63+ is ~20. (From CPP)
thebacon is offline   Reply With Quote
Old 03-09-2012, 04:00 PM   #12
Heater63
Heater63's Avatar
As said above, the parts stores (O'Reillys) will "loan" you a ball joint press, just leave a deposit.
The lowers press in and out, USE THE TOOL!
292 + TKO500
Heater63 is offline   Reply With Quote
