Old 04-23-2011, 09:51 PM   #251
my4by2
my4by2's Avatar
Re: 1977 Chevy K30 Crew Cab Build
Dang, dang, dang!!!!! Just lost a set of NOS headlight bezels on eBay for $5.00 measly bucks.... Those would'a been SWEET!!! Already bought new ones from LMC Truck, but the metal stock ones are always better. May have them re-chrome my original ones & repaint the inner section black to match the LMC Special Edition grille we are using.
my4by2 is offline   Reply With Quote
Old 04-24-2011, 04:38 PM   #252
Conundrum
Conundrum's Avatar
That sucks!
Truck is coming along nicely though.
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r
http://67-72chevytrucks.com/vboard/s...d.php?t=460030
97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver
220,000 miles, all stock for now
Conundrum is offline   Reply With Quote
Old 04-25-2011, 09:58 PM   #253
my4by2
my4by2's Avatar
Jeesh, how freakin' long does it take to get a set of door latches for a 73-87 pickup???? Ordered new Goodmark units through Summit over a month ago & they are STILL on back order... One set shows expected to arrive mid-June & the other won't until the beginning of July
Old 04-25-2011, 10:07 PM   #254
Conundrum
Conundrum's Avatar
A friend of mine had the same kind of problem with fenders for his elcamino. It was 2 or 3 months and he ended up calling goodmark directly to see what the hold up was, it wasn't much longer and he finally got his fenders.
Old 04-25-2011, 10:35 PM   #255
my4by2
my4by2's Avatar
May end up doing the same - have a little cushion as the truck shouldn't go in for the body work to start until the beginning of June & will still have a little time after before he actually needs those parts. He can also use my old ones to do all the alignment & stuff too.
Old 04-25-2011, 11:15 PM   #256
my4by2
my4by2's Avatar
Looks like Mario may go with a PPG Corvette Arctic White paint (4185) on my truck. Should have a really clean look to it - especially after all the panels are nice & flat! Jury is still out on what he'll use for the semi-glass black hood stripes. He also will need to paint the LMC Special Edition grille with that paint & the inside of the headlight bezels as well. The red for the striping around those rally stripes will most likely be the same that was used on the "6.0L" part of my fender badges - believe it was Ford Vermillion Red.
Old 04-27-2011, 04:38 AM   #257
my4by2
my4by2's Avatar
Here's the bell housing off of that 85 1-ton Trevor purchased. They had to mill out the opening for my application. It didn't look all crappy like this though when it got installed!
Old 04-27-2011, 04:42 AM   #258
my4by2
my4by2's Avatar
New Mast Motorsports engine after getting dropped into the truck for the first time!!! It's all kinda loosely in there right now as they are just doing it all for mock-up. The whole front end will get ripped apart again prior to going out for paint at Novelli's.
They will be installing the engine oil cooler on the front cross member too - it's a slick little aluminum finned unit they use a lot & the engine's already plumbed for an external cooler anyway.
Old 04-27-2011, 08:17 PM   #259
my4by2
my4by2's Avatar
And BTW - that hideously huge master cylinder will be gone eventually.... Maintaining the hydra-boost set-up (after a freshening + paint), but going back with a Wilwood master cylinder & adjustable proportioning valve from CPP or someone. Should add a nice touch to the engine compartment & not look so "dated".
Old 04-27-2011, 08:49 PM   #260
my4by2
my4by2's Avatar
Well, looks as if they got the front clip all mocked back up in place! There's a nice new scratch on the front of my left front fender, but it's all getting stripped & redone anyhow so guess no biggie - still not happy about it though... Core support still needs a few mods & then out to powder coat before it's all finalized.
Those aren't the headlights staying on the truck either since I have a set of LED headlights for it we are going with. Really starting to move along pretty good as of late so I am pretty happy!
Old 04-27-2011, 08:55 PM   #261
my4by2
my4by2's Avatar
Well, can't really understand why they powder coated the inner fenders prior to mock-up, but judging by the scratch on top of the left one they'll be picking up the cost of re-doing at least one of them....
You can see the new clutch master cylinder assembly on the firewall in the first one. The reservoir however is temporary as it'll be getting an all new one before it's all said & done.
Motor will look a LOT better once the accessories arrive & we get the 3-pc cover installed! They should be getting the radiator in soon & then they can start mocking up the K&N cold-air intake kit too!
Also gotta work out where & how to mount the batteries - one on each side of the engine compartment.
Old 04-27-2011, 09:33 PM   #262
menace121978
menace121978's Avatar
nice build dude! what k&n are you going with? the one that fits the motors stock application?
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 04-27-2011, 09:36 PM   #263
my4by2
my4by2's Avatar
Yep, can't recall the exact part number but it's for a 2008 GMC 2500HD with the 6.0L - which is what I got the first motor out of. It's their F.I.P.K. with the black plastic tubing - not the chrome gaudy one. Hoping it comes out looking like it belongs in there & want them to fab a base up that will link into the factory opening in my core support for bringing in cool air to the filter.
Old 04-27-2011, 09:46 PM   #264
menace121978
i just bolted up the chrome gaudy one on my build i love it... sets it off and matches the S & P headers interested to see how they get it mounted
"Dennis the Menace"
Old 04-27-2011, 09:50 PM   #265
my4by2
my4by2's Avatar
Not knocking chrome don't get me wrong - when I built my '82 way back when I used a LOT of chrome & stuff on it and just got a little sick of it... And trying to keep my engine compartment kind of "stock" looking & subdued - although much more modern. I also am using the coated S&P headers - but rest of exhaust will get black ceramic coating.
Hopefully they'll start all the intake mock-up & stuff once the accessories all arive so they can see how much room they have to work with. Also gotta figure out the radiator surge tank & mounting.
Old 04-27-2011, 09:52 PM   #266
my4by2
my4by2's Avatar
And I am using the same 3-pc covers you did - just leaving mine in black. Am going to have the pin striper dress 'em up some though prior to final install, so they should look great!
Old 04-27-2011, 10:01 PM   #267
menace121978
i totally understand what your saying... i don't know where or why it happened but mine has taken a turn somewhere in my build of more 'show' than i had planned and i love the 3 piece covers... really sets the LS swap from others.
"Dennis the Menace"
Old 04-27-2011, 10:05 PM   #268
my4by2
my4by2's Avatar
Understand where you're coming from on the build turning... My original plans were MUCH simpler, but things kind of happen & away you go on making the truck so much more! Although mine will end up as my daily driver when I come home for good - it's gonna see it's fair share of shows & events prior to that day.
BTW - I totally love your truck's build man - very nice!!!!!
Old 04-27-2011, 10:08 PM   #269
menace121978
thanks bro i apprieciate that! i'm going to drive the hell outta mine too!
"Dennis the Menace"
Old 04-27-2011, 10:13 PM   #270
my4by2
my4by2's Avatar
Damn man, just looked up your location on Google Earth - you're like 20 miles from the shop doing my truck.... They are up in Auburn! May have to come check you out when I fly in during my R&R in late July!!! Would love to see your rig in person!!!
Old 04-27-2011, 10:32 PM   #271
menace121978
that would be SWEET! your welcome to come by anytime bro... if you need me to check on yours or anything let me know. i'd really like to see the work they are doing there
"Dennis the Menace"
Old 04-27-2011, 10:54 PM   #272
my4by2
my4by2's Avatar
Shoot, ur welcome to go by their shop anytime man. Just let them know you know me from this thread & that you want to see their work. They're really laid back & easy going there. Will definitely plan to swing by & see yours come July!
Old 04-28-2011, 12:20 AM   #273
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Can you post a pic of your current hydra-boost set-up? I'm trying to figure out my 6.0L lines and what I need to link up and the hydraboost thing isn't easy for me as a noobie on these swaps....
Basically I would like to switch out my master cylinder too and get rid of the vacuum assist but I'm not sure what to order instead and then install.
This is what I found so far to be the best info on the web that I'm kind of following:
http://forums.corvetteforum.com/c3-t...st-brakes.html
Thanks!
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 04-28-2011, 03:07 AM   #274
my4by2
my4by2's Avatar
Here's about the best pic I can find of the "original" set-up for the hydra-boost when I bought the truck. Mine isn't a conversion as the vehicle has always had it, we are just upgrading the actual master cylinder & only refreshing the stock hydra-boost unit. Unfortunately this pic really doesn't show anything about where the lines hook to on the power steering reservoir... And since the shop has yet to get my new pump/reservoir combo in, I can't really get one showing you how they connect down there either...
My stuff should be in next week & then they'll get all the lines run - will try to get a good pic for you of it all once that happens.
Old 04-28-2011, 11:41 AM   #275
75ChevyGuy
GM Parts Guy
75ChevyGuy's Avatar
Wow! I really like all the attention to detail on this rig. This is gonna be a when its all done. And I'll put money on that!
1975 Chevrolet C-10 Custom Deluxe (DD/WIP)
1989 Chevrolet C1500 reg cab stepside (Winter Truck)
1977 Harley Davidson XLH 1000 (Summer Cruiser)
75ChevyGuy is offline   Reply With Quote
