Old 04-28-2011, 09:18 PM   #1
late68
late68's Avatar
Need some roof opinions......
Okay so my roof is pretty ruff, My question to all of you out there is should i try and buy a inner front panel and fix the outer skin or should I just cut it off and weld another decent one in place of it. I have somthing set up to get another roof for free. But lets get some feedback.
late68 is offline   Reply With Quote
Old 04-28-2011, 09:31 PM   #2
71swb4x4
71swb4x4's Avatar
Re: Need some roof opinions......
That is horrible. Definitely a new roof.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 04-28-2011, 10:14 PM   #3
late68
late68's Avatar
Talking Re: Need some roof opinions......
HA..... I figured I would get that response.
Old 04-28-2011, 10:23 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
I had a cab like that and I scrapped it. It also had issues around both fresh air vents in the kick panels. (and other places)...
LockDoc
Leon
Old 04-28-2011, 10:34 PM   #5
OARNGESI
OARNGESI's Avatar
Is the rest of the cab good
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 04-28-2011, 10:41 PM   #6
late68
late68's Avatar
Everything on the cab is good except the roof. Rockers, and cab corners have already been replaced.
Old 04-28-2011, 10:46 PM   #7
71swb4x4
71swb4x4's Avatar
In TX you should be able to find a whole cab for relatively cheap and save yourself the time and expense of replacing that roof.
Old 04-29-2011, 11:57 AM   #8
sanford66
sanford66's Avatar
WOW! I thought the roof was bad in my 68! Joseph
1970 Chevelle Nomad station wagon
1966 C-10 lwb,250-six,granny 4speed
1966 C-10 lwb,factory A/C,Custom Cab
1954 Delray 2-door sedan [rat rod project]
sanford66 is offline   Reply With Quote
Old 04-29-2011, 01:11 PM   #9
late68
late68's Avatar
lol.... yea it is pretty bad. But the really bad part is that sombody ( PO ) has some sort of copper filling all over the roof, i'm assuming it was where all the prior rust was...
Old 04-29-2011, 01:23 PM   #10
Jessechop
Thats brazing. Old way of doing stuff. I never thought I would be one of the rare ones that can still braze
Jessechop is offline   Reply With Quote
Old 04-29-2011, 01:35 PM   #11
my67c20
The best plan would be to graph in halfway to the back of the door, half way down the pillar and a good 12 inches towards the center of the truck. There is at least 3 panels in that general area and odds are thay are all in pretty rough shape. Doing the inner and outer skins is a bit of a pain but it can be done with patience, finding and replacing the middle panel is a complete pain. Find a good cab or replace the whole top. The last 2 allow you the option of getting them cleaned and primed to do the swap in a weekend. Been there doing that.
my67c20 is offline   Reply With Quote
Old 04-29-2011, 02:02 PM   #12
msgross
msgross's Avatar
we swapped roofs in my 69 LWB project, check my signature... wasn't too hard but if you have a better cab then i'd go that route.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 04-29-2011, 03:38 PM   #13
mbgmike
Get the one for free if good and use it. WOuld not waste time and money on that. better cab is always the best route as stated. Or make a roadster
mbgmike is offline   Reply With Quote
Old 04-29-2011, 05:38 PM   #14
late68
late68's Avatar
Well I talked to one of our buddies on the board here and he is gonna meet me in Humble on sunday to drop off the roof, free of charge. Cant beat that so cutting off the roof and welding the used back on is the plan for now.
Old 04-30-2011, 10:12 PM   #15
RangerCB29
Edit
Last edited by msgross; 05-01-2011 at 04:13 PM. Reason: please become a paid subscriber if you want to search for parts to buy, thanks...
RangerCB29 is offline   Reply With Quote
Old 04-30-2011, 10:35 PM   #16
crazy longhorn
Fabricate till you "puke"
Brace the cab, across the door openings, & an x cross the middle wouldnt hurt, before you cut the top off. Leave the doors on, & "fit" the new top to the truck. Take your time, & cut the pillars a tad long(grind to fit)....best of fun,crazyl
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 05-01-2011, 07:05 AM   #17
elf w/capital T
yikes, weld on a new top section man, prolly your best bet.
elf w/capital T is offline   Reply With Quote
Old 05-01-2011, 10:03 AM   #18
cleanfreak
cleanfreak's Avatar
crazy longhorn said what I did to a tee , worked out really nice. Still would look for a good cab if I was in tx.
cleanfreak is offline   Reply With Quote
Old 05-01-2011, 02:09 PM   #19
Richard H.
Spanked once
Richard H.'s Avatar
Here is some pictures in my build thread.
http://67-72chevytrucks.com/vboard/s...2&postcount=12
When I did this no one sold roof skins but the inside header was available. See how bad it really is by removing the header panel. You are not gonna buy another top that is not rusting already inside.
The ole 350 budget build.
Richard H. is offline   Reply With Quote
Old 05-01-2011, 03:11 PM   #20
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Good to see you deciding on a new roof as that's the route id go also.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 05-01-2011, 09:56 PM   #21
SIXSHOOTER 72
SIXSHOOTER 72's Avatar
Hay, maybe a convertable would be easier? Just kidding.
SIXSHOOTER 72 is offline   Reply With Quote
Old 05-01-2011, 11:14 PM   #22
70cst
70cst's Avatar
If rust isn't fully removed it will come back. You can pay now or pay later...my vote goes for a new roof.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 06-13-2011, 11:23 PM   #23
late68
late68's Avatar
Well I have everything fitted up the best to my ability. Hoping to have everything on the roof welded up this weekend. I have been working pretty hard on getting all the front end stuff done, after the roof is finished it "should" be smooth sailing.... ( knock on wood )
