04-28-2011, 09:43 PM | #1 |
Active Member
Shocking the bouncing. Need suggestions.
I drove my old 68 GMC (leaf springs) out in the country today and drove through some construction and gravel roads and I got tired of the bouncing. I was literally sliding sideways on the corrugated gravel road.
It's not because of defective shocks. They're about 2 years old and I'm almost certain they are Monroe Matics or something similar. They just seem to be too stiff or not responsive enough. My old 69 with coil springs in the rear was certainly smoother but can't remember the shocks I was using. I'm looking to smooth out some of the bouncing without sacrificing stability. Anyone have any recommendations and/or experience on better shocks? |
04-28-2011, 10:33 PM | #2 |
Re: Shocking the bouncing. Need suggestions.
This may not be any help but on my 69 with coils i am running monroe shocks and they seem to work great. came with a lifetime replacement warranty. cant beat that for $16 a shock
1969 C-10 LWB 388 SBC Vortec Heads 10:1 Lunati 60103 cam Weiand intake Quadrajet Carb 12 Bolt 3:73 posi 700r4 Hedman Headers 1998 Dodge Ram 1500 Reg. Cab Long Box 4X4 5.9L 183k miles 1956 Ford F-100 Longbed with Original 272 and 3OTT 1995 C1500 ECSB 6.5 Diesel 4l80e (Camper puller) 1997 Dodge 3/4 ECLB V10 (MPG machine) |
04-28-2011, 10:50 PM | #3 |
i thought that was normal... the 2 leaf trucks i've had both did it. i've not taken the coil rear truck down any such road.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current 1969 K20 - V8, 465, 221, Eaton, D44 2012-current Nothin' but drums on all 4 corners! past horses in the stable 72 C10-short step (97-02), 68 C10-long fleet (06-12) |
04-28-2011, 11:15 PM | #4 |
Active Member
Yeah, I figured much of it is just truck type bouncing but I'm also comparing two Furd rangers both with leaf springs, 3.0 engines and specs pretty much the same. The 98 is fairly smooth with original stock springs (I think Bilstein) and I just put inexpensive Gabriel shocks on the 94 and it bounces pretty bad.
It just seems to me that the responsiveness of the Monroes and the Gabriels is not as good as the original stock shocks. Anyone use Bilsteins that can give some input? |
04-29-2011, 03:34 PM | #5 |
You need to get the biggest badest shock listed for these trucks for the front. The rears can use any good shock.
