Old 04-28-2011, 10:19 PM   #1
ghettoluxury
ghettoluxury's Avatar
TBI Fuel or no Fuel that is the question
I have a 88 V30 with a TBI 350. The fuel pump will not run when you turn the key on and the injectors will not fire. If I run a power lead to the extra wire on the relay then I get the pump to run and the injectors will fire but not enough to start the truck. If I shoot starting fluid in before attaching the power lead it will start up and stay running. Once running I can remove the lead an it will run fine.
So my question is what makes the pump start for the first time and also primes the intake for the start. The injectors just give little pulses when tring to crank over with the lead hooked up.
Here is a pic of the lead attached to the relay.
Thanks for the help!
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 04-29-2011, 01:00 AM   #2
Blazenherbs
Blazenherbs's Avatar
Re: TBI Fuel or no Fuel that is the question
Try to check for spark those truck have a ignition control module in the distributor that control the spark and Fuel pump...
http://www.summitracing.com/parts/ACC-35362/
Blazenherbs is offline   Reply With Quote
Old 04-29-2011, 01:01 AM   #3
Blazenherbs
If theirs no spark the module is bad and wont feed gas to the injectors
Their two diferent ones for a 4pin and 8 pin
http://www.summitracing.com/parts/ACC-35361/
Old 04-29-2011, 07:42 AM   #4
ghettoluxury
There is plenty of spark just no fuel.
Old 04-29-2011, 11:13 AM   #5
Blazenherbs
Unless the relay is Bad....
Old 04-29-2011, 07:42 PM   #6
ghettoluxury
replaced it, that was my first thought
fuel pump, no fuel, tbi
