03-27-2002, 02:02 PM | #1 |
What does 2 part epoxy primer mean??
I am wanting to get some primer for some parts, And I hear the words 2 part epoxy primer. I know about the epoxy primer, but don't understand the 2 part, Does 2 part mean mix with reducer and primer, and spray only one time, Can someone help???? Thanks!
------------------ 72 CHEVY FLEETSIDE 4X4 SHORTBED,8" SUSP. LIFT, w/ soon to be 38" Swampers (IN RESTORATION) 1967 CAMARO (283 CU.) Dillsboro, Indiana.. AOL IM: HIGH724X4 I am NOT Addicted to the Board (PLEASE HELP!!!)
72 CHEVY FLEETSIDE 4X4 K10 (SOLD TO JAMIE72, BUT BLAZER GAL PULLED AWAY WITH IT LOL!!!) Will Own one Again!!! 1967 CAMARO (PRO-TOURING PROJECT) Lawrenceburg, Indiana.. AOL IM: kbillcad |
03-27-2002, 02:31 PM | #2 |
It means that you mix the paint with a hardener and then spray the mixture. With the DuPont product it has to stand for a hour or so after mixing and before spraying.
Bernie |
03-28-2002, 02:58 AM | #3 |
It also means you need to wear special respirator! Stuff can kill you if you don't know what your doing and have the right equipment and ventilation. Check with a pro on this one!
1967 K30 461/TH400/Np205/D60/14FF/BDS MTZ 375/75/16 on 16x10 Pro Comps |
03-28-2002, 07:36 AM | #4 |
Yes, that is one downside of 2 part, it is VERY bad to breath. I used a fresh air resp. when I sprayed it. (line going outside for fresh air). Learned the hard way though. Sprayed a sandrail chassis with it once, no resp. coughed for days. Probably didn't help the body any either.
You can buy a fresh air for about $200 I believe, or rent them also. ------------------ Jeff Scott '70 GMC Stepside, Short box '67 Camaro '63 Nova '92 GMC typhoon
Jeff Scott '70 GMC Stepside, Short box '63 Nova '92 GMC typhoon '95 Tahoe |
03-28-2002, 01:52 PM | #5 |
two part you mex only what you are going to need. The unused stuff will last a lot longer than a one part and it is a better quality. DUPONT you don't hace to let it sit for an hour before spraying I use the stuff every day it is PPG that you have to let sit for one hour before spraying.
68 gmc 70 chev |
