Old 04-30-2011, 12:59 AM   #1
thun
thun's Avatar
Rochester Quadrajet Smog Delete Question
In the picture below there are 3 tubes. 2 little ones in the left circle and one big one in the right circle. The big one runs off to the canister in front driver side and small ones look like they run to the A.I.R. system on top of the valve covers. Can I remove and what's the best way to plug them? The car does not have to pass emissions.
86 C20 2wd with 454 and Turbo 400
thun is offline   Reply With Quote
Old 04-30-2011, 01:51 AM   #2
Grouten
Re: Rochester Quadrajet Smog Delete Question
im pretty sure the top one on the left is the choke, make sure you keep that one connected, the one going to the smog can dont make a difference if it dont have to pass emissions
and for plugging them, i just cut the hose off and put a screw into what was left of it
Grouten is offline   Reply With Quote
Old 04-30-2011, 06:24 AM   #3
Pop's C-10
Pop's C-10's Avatar
tha one going to tha valve cover is tha PCV valve...keep that & tha hose running to tha choke diapram & get a vac cap fot tha other one.
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
