Old 05-01-2011, 01:22 PM   #1
baclay9
1989 K5 Blazer, Cruise control surging
We have been trying to figure out the cruise control surge on my buddies K5. When you set the cruise at any speed you can feel the power surging. We thought maybe it was the speedo because the needle was jumping a little but we changed it and it still does it.
The surge isn't drastic but you can feel it. Thanks for any suggestions.
baclay9 is offline   Reply With Quote
Old 05-01-2011, 02:13 PM   #2
Liddy71
Liddy71's Avatar
Re: 1989 K5 Blazer, Cruise control surging
cable driven it may need lube
Liddy71 is offline   Reply With Quote
Old 05-01-2011, 02:40 PM   #3
baclay9
cable driven? I thought it worked off of the little "laser" that gets bolted to the back of the speedo.
Old 05-01-2011, 06:10 PM   #4
Liddy71
Liddy71's Avatar
Iam not sure what year but some use to have the speed cable come up from the trans to a box on the inter fender then a cable from it to the cluster
Old 05-02-2011, 01:28 AM   #5
tobiahr
tobiahr's Avatar
it could also be a vacuum leak effecting the actuator attached to the throttle at the carb
tobiahr is offline   Reply With Quote
Old 05-02-2011, 07:05 AM   #6
baclay9
We were actually thinking maybe that was it. He bought some vaccumm line yesterday and we are going to try changing some of it today and see iff we can track a leak down.
Old 05-02-2011, 11:46 AM   #7
Jonboy
Slots go on anything!
It may also be a leak in the diaphragm of teh servo. Check it with a vacuum pump to see if it holds.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 05-02-2011, 02:07 PM   #8
78 Chevyrado
My 87 used to do that, so I ended up taking the actuator apart to see what was wrong. I didn't find anything damaged so i cleaned it and closed it back up and then it worked fine. Musta just had a bad seal or something.
78 Chevyrado is offline   Reply With Quote
