06-09-2010, 02:45 AM | #1 |
fuel tank repair
anyone ever had a fuel tank repaired instead of replaced. Mine is really in bad shape inside. having trouble locating a replacement. found some places online about repairing them, but don't know if it is a trustworthy solution.
AZ Chev Man 1st Ride 1958 Chevy Apache 2nd 1972 C10 1968 Chevy P10 Step Van '01 Blazer, '03 Astro Last edited by AZ Chev Man; 05-04-2011 at 04:04 AM. |
06-09-2010, 04:56 AM | #2 |
Re: fuel tank repair
i just put in a new one as it had pinholes all along the bottom and when i got it out i looked inside and it was thick with RUST all along the bottom of tanksweet as now
06-09-2010, 06:51 AM | #3 |
is your old tank leaking??
they arn't that hard to clean. i use a pressure washer to clean th cunk and residue from the 40years of crap. then look and see what it looks like if real bad then will treat with muratic acid{swimming pool chemical) tthen rince again with clear water let dry and if in doubt i coat with POR15 tank sealer. have never had any problems doing it this way and a pretty cheap fix
06-09-2010, 10:12 AM | #4 |
http://www.gastankrenu.com/
I have used this place a few times with a great outcome |
06-09-2010, 10:49 AM | #5 |
IF IT'S A REGULAR OLD BEHIND THE SEAT TANK, I'LL BET THAT YOU CAN FIND ONE FROM A MEMBER THATS FAIRLY LOCAL FOR FREE OR NEXT TO FREE. I'VE TAKEN DOZENS TO THE CRUSHER OVER THE YEARS BECAUSE I COULDN'T GIVE THEM AWAY. WITH ALOT OF PEOPLE GOING WITH BEHIND THE AXEL TANKS, THERE SHOULD BE PLENTY OF GOOD USED ONES AROUND. ANOTHER GOOD SOURCE IS BONE YARDS. THE EPA MAKES MOST (IF NOT ALL) JUNKYARDS DRAIN & REMOVE THEM BEFORE PUTTING THEM IN THE YARDS TO PART OUT. ALOT OF BONEYARDS JUST PUNCH HOLES IN THE UNDERSIDE TANKS NOWADAYS TO DRAIN THEM, BUT THEY USUALLY DON'T PUNCTURE THE BEHIND THE SEAT TANKS. SOUNDS LIKE A GOOD TIME TO THINK ABOUT INSTALLING A UNDERBED TANK. A SIMPLE & VERY WORTHWHILE UPGRADE. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
06-09-2010, 10:52 AM | #6 |
As 'junkyardjohn' said. I have an extra behind the seat tank. I am a local Glendale resident too so let me know if you need that type.
1972 C10 LWB Cheyenne Super God Said,"Owning A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still Gay" ........................__ ..........._______ |__\__ ..........|__(O)______(O)] |
06-09-2010, 11:31 AM | #7 |
wow what a great bunch at this forum. thanks all of you. sorry didn't state before, my tank is the type behind the rear axel. 30" wide by 13" tall by 19" deep.
Thanks for the offer 72mistressc10. wish that would work.
AZ Chev Man 1st Ride 1958 Chevy Apache 2nd 1972 C10 1968 Chevy P10 Step Van '01 Blazer, '03 Astro |
05-04-2011, 03:40 AM | #8 |
Haven't been on in a while... Update on the 68... Found a new replacement fuel tank at a pretty neat place called Brothers in Southern California... Replaced the tank and it solved the problem....Apparently the inside of the old tank had been refinished years ago and was peeling off and getting into the fuel causing so many problems. Humbled to say its up and running great...starts right up and runs like a champ...Thanks for all the help out there!!
Tags |
fuel tank, gas tank, gas tank repair, p10, rusty gas tank |
