Old 05-04-2011, 09:54 PM   #1
1971ChevyTruck
1971ChevyTruck's Avatar
New cowl hood problems
I installed the cowl hood on my truck and it seems that it is twisted or something. The hood wants to hit the fender on the back passenger side corn but the fron passengerside corner has a big gap between the fender and hood. Any ideas??
1971ChevyTruck is offline   Reply With Quote
Old 05-04-2011, 10:02 PM   #2
Fldawg
Fldawg's Avatar
Re: New cowl hood problems
Your not the only one with this probelm, my doors and fenders had to be aligned to get the hood to work was not easy, the quality control on these hoods are not very good
Fldawg is offline   Reply With Quote
Old 05-05-2011, 12:59 AM   #3
AusTx68
AusTx68's Avatar
Yep, the initial fit of my 68' cowl hood had me looking for a stock hood. I ended up keeping it and fought to make it look right. It's still not correct but it's close.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 05-05-2011, 01:02 AM   #4
VA72C10
VA72C10
VA72C10's Avatar
Just making sure you had a stock hood adjusted and on before swapping to the cowl? If not, the rad support can have something to do with this....
if it's definitely just the hood, I watched a body man grab one corner of a hood and tweak it on purpose twice and it lined up perfectly after the second time....so all is not lost
Old 05-05-2011, 11:24 AM   #5
AusTx68
AusTx68's Avatar
So what about the aftermarket stock hoods? Do they have the same problems?
Old 05-05-2011, 11:48 AM   #6
ZombieWeinerDog
ZombieWeinerDog's Avatar
i actually had to shave some of my hood to make it fit, it would hit the grill shell and not close at all.
1972 longbed- 454
1967 shortbed- 355
ZombieWeinerDog is offline   Reply With Quote
Old 05-05-2011, 12:08 PM   #7
custom1970
Member
custom1970's Avatar
I also had the same problems with mine, PITA
custom1970 is offline   Reply With Quote
Old 05-05-2011, 01:23 PM   #8
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Is the gap on the driver side consistent all the way down?
Zoomin is offline   Reply With Quote
Old 05-05-2011, 02:02 PM   #9
6772owner
Gearhead
6772owner's Avatar
My PO installed cowl hood fits like crap as well, unfortunatly they painted everything with it fitting like crap, so the truck would need repainted to fix it at this point. (I think at least)
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 05-05-2011, 02:29 PM   #10
Autoblueprint
Autoblueprint's Avatar
Had a body and paint man do my hood ( along with all else ) and EVERYTHING needs to be in alignment ( fenders, rad support and bushings, CAB MOUNTS, etc. ) for the cowl hood to fit properly. Hood hinges need to be good too. It is a tedious process but it can be done. Speak with some body guys at body shops in your area and see if someone works on the side who can get it done for you at a reasonable fee.
http://www.autoblueprint.com/1971_pa...dypaint_1.html
Autoblueprint is offline   Reply With Quote
Old 05-05-2011, 03:14 PM   #11
big_al_71
big_al_71's Avatar
Mine is also not aligned perfect two body men later and it still not perfect..
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 05-05-2011, 09:39 PM   #12
CaptRMW
Custom Sport W/T
CaptRMW's Avatar
Location: Tarpon Springs,Fl & Annapolis,Md. ....................Quaint drinking villages with a fishing problem
I bought a "Goodmark" = (Badmark) cowl induction hood for my '70 CST and removed a perfect fitting original hood and installed it, the big surprise was a 5/8" gap (probably closer to 3/4") between the hood and back corner of the fender on each side. A lot of massaging with the Porta Power and a couple of 12 packs later it fit great. 3 years later it rusted through where the rice farmers "foamed" the front to back braces with no rust preventive underneath. I found it a new home for 1/4 the original price and now have the original where it belongs. Aftermarket sheetmetal should stay in the scrapyard where it originated. To those that think you will have a "new" part fitting properly, dream on....Roger
CaptRMW is offline   Reply With Quote
Old 05-05-2011, 10:10 PM   #13
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
mines a tri-plus and looks like 6772owners. fit is terrible but my old hood was garbage and I really like the cowl hood look.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 05-05-2011, 10:25 PM   #14
bigsnookmaster
bigsnookmaster's Avatar
Mine fits very well,......but it took alot of metal work! I don't believe there is a bolt on aftermarket piece that fits like it's supposed to!
bigsnookmaster is offline   Reply With Quote
Old 05-06-2011, 03:25 PM   #15
AusTx68
AusTx68's Avatar
Anyone know if stock aftermarket hoods have the same problem??
Old 05-08-2011, 01:13 AM   #16
ATrain707
heres mine, it lined up the first try. paid 350
ATrain707 is offline   Reply With Quote
Old 05-08-2011, 01:21 AM   #17
Jeffs70
Jeffs70's Avatar
my hood did the same as 1971ChevyTruck's hood and I had to modify it to get it correct.
Jeffs70 is offline   Reply With Quote
Old 05-08-2011, 01:34 AM   #18
ATrain707
were did you order your hood from/maker?
Old 05-08-2011, 04:00 AM   #19
AusMarty
My original stock hood has exactly the same problem gap too wide at right front !!, lines up perfect on the left
AusMarty is offline   Reply With Quote
Old 05-08-2011, 11:33 AM   #20
Zoomin
Man of Mini-Talents
Zoomin's Avatar
You ought to take two measurements diagonally from corner to corner on the engine compartment and then again on the hood to determine which is the real culprit. If the two measurements on the engine compartment aren't equal, then it's off - ditto with the hood. Could be both are off, but until you determine which it is, you won't get it to fit.
Old 05-08-2011, 12:23 PM   #21
Boog
laying low
Boog's Avatar
Body panel alignment isn't exactly science as some might think. Any good bodyman will tell you the best panel fitments begin at the doors. Check that. Starts with the cab on the frame. Get it square. Get the doors right then move on to the fenders then the hood. As said measuring helps a bit.
These trucks were designed with a good bit of panel adjustability. It helps since many of us find used or new replacement doors, fenders etc don't fit like the ones we are replacing. Even panel gaps was not a priority when these trucks were designed.
As for the fitment aspect of aftermarket body panels I can't say as I don't buy them. But even the oe parts sometimes require a bit of tweaking.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 02-15-2012, 03:09 AM   #22
trevorrhine
trevorrhine's Avatar
yes. the aftermarket stock style hood has the exact same problem you guys are describing...I'm fighting trying to get mine to fit decently...My cab is square, but I'm just gonna have to keep tweaking things until I get it as close as possible.
1967 Chevy c10 SWB
Project "Daily Driver"
Build Thread:
http://67-72chevytrucks.com/vboard/s...ar#post4953311
trevorrhine is offline   Reply With Quote
Old 02-15-2012, 09:08 AM   #23
The problem we had with the 67/68 cowl hood we had (other than fender to hood gap/different radius) was at the back edge of the cowl scoop it was shaped completely different on one side from the other. One side dropped down square and vertical and the other side cut back with a slant (about 1/2-3/4").I mean,they were completely different and it would be obvious to a mole!
Old 09-14-2012, 08:49 AM   #24
bamafrost
bamafrost's Avatar
Bought a "Goodmark" aftermarket hood (their "better version at $500 w/shipping). After countless hours of metal work it still fits like S@%t. My advice...buy the best OE hood you can afford and make it work. Repop stuff is crap. Had the same problems with Goodmark fenders and doors...junk.
Bamafrost
"Wars fought, uprisings quelled,
Coup d'Etats planned...right after my nap".
'68 Rambler American 2 door post
Built 340/727/8.75 w 3.73 posi
'68 C10 shortie soon to have a 2.5/4 drop
and new Americans: 16" x 8" chrome IROC's
bamafrost is offline   Reply With Quote
Old 09-14-2012, 08:58 AM   #25
lolife99
67-72 parts collector,…
lolife99's Avatar
X2
Good advice^^^
Keith
Convert to disc brakes.
