Old 05-05-2011, 01:49 PM   #1
sduckworth13
sduckworth13's Avatar
which year of axle relocating kit do i need
I have a 1967 gmc 3/4 making a 5 lug disc/drum and lowering it 4/6. I have the rear end out of a 1974 chevy 1/2 ton. Can I buy rear axle relocators for the 73-87 chevy trucks? I did have a GM corporate 8 lug 14 bolt 10.5 ring out of 73-87 chevy truck in it previously.
sduckworth13 is offline   Reply With Quote
Old 05-05-2011, 02:56 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: which year of axle relocating kit do i need
Part No. 61160
http://www.stockcarproducts.com/trkarm1.htm
You will also need a way to reattach your track bar the the '74 rearend housing.
The easiest way is to use the Super Track Bar from ECE.
Keith
Convert to disc brakes.
Old 05-05-2011, 04:34 PM   #3
SCOTI
SCOTI's Avatar
Just to 100% confirm.... this is going to be a truck-arm suspension & not leaf springs?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 05-05-2011, 09:54 PM   #4
sduckworth13
Thanks Keith, where do you find all these cools links.
Old 05-05-2011, 10:12 PM   #5
lolife99
lolife99's Avatar
Just lots of internet time, and helpful people on this board.
I save these links to my "favorites".
Keith
Old 05-05-2011, 10:16 PM   #6
sduckworth13
Scoti, Its leaf springs only. I don't have the track bar on my 1967 GMC 3/4 ton. I got a little antsy today and went to LMC and bought the axel flip for a 1973-1987 Chevy 1/2 ton. Bad move, #1 because Keith already told me to get the 67-72 chevy flip, 2# I had to drive another 35 minutes to take it back because the the leaf spring bolt hole was in the back half of the axle relocators and not in the center. I figured it might have worked since my 12 bolt rearend is out of a 1974 Chevy. I have it mocked up, just waiting to get my flip kit so I can weld in place the shock mounts where I need them and paint it too.
Old 05-05-2011, 10:33 PM   #7
lolife99
lolife99's Avatar
My link is the wrong parts.
I thought your truck was coil spring.
Now I see it is a leaf spring truck.
Thanks SCOTI,... for asking the correct questions.
I guess have your truck confused with another member.
I talk to too many people in PM's I guess.
Keith
Old 05-05-2011, 10:34 PM   #8
sduckworth13
No problem Keith, thanks for helping me out.
Old 05-05-2011, 10:36 PM   #9
lolife99
lolife99's Avatar
The hole is suppose to be offset and NOT in the center of the flip kit bracket.
It is that way, so it will move the rearend "slighty" rearward,... to keep the rearend centered in the wheel opening.
(and to help with the driveshaft length after flipping the rearend on top of the leaf springs).
Keith
Old 05-05-2011, 10:39 PM   #10
sduckworth13
lol, oh. I should have took a picture. It just looked too far back from center, almost too the back of the bracket.
Old 05-05-2011, 11:11 PM   #11
sduckworth13
Keith, this is here they some what looked like but the hole is about the right spot. The top one is the bottom of the bracket and the second is my side view
Old 05-05-2011, 11:32 PM   #12
lolife99
lolife99's Avatar
Those are correct for 73-87 trucks.
Did you try to fit them on your '67 3/4-ton leaf springs?
The hole goes towards the "front of the truck", when installed.
Keith
Old 05-05-2011, 11:35 PM   #13
lolife99
lolife99's Avatar
Your lower shock mounts on the '74 rearend housing will also have to be modified/fabbed,... to match the position of your '67 shocks.
Keith
Old 05-05-2011, 11:35 PM   #14
sduckworth13
I didn't try it. I just looked at the bolt hole location and knew or aleast thought I knew I had the wrong ones.
Old 05-05-2011, 11:38 PM   #15
sduckworth13
I have the shock mounts shaved off and grinded down, I was going to wait to weld them in place after i got the flip kit on so I could mark my locations for the shock mounts.
Old 05-05-2011, 11:42 PM   #16
sduckworth13
The PO had both the shock mounts facing toward the front on the 14 bolt corporate that was in it. I'm going to place one facing the front and one facing the rear. I hear that keeps the rear end from pitching or rolling.
Old 05-05-2011, 11:46 PM   #17
sduckworth13
Thanks keith for the help, I didn't know which way that hole was supposed to face on the kit. It just came with worded directions, it never mentioned which way the hole was supposed to face. I'll post my pics when I get my flip kit installed.
Thanks,
Scott
