Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Closed Thread
Old 03-16-2011, 09:02 AM   #1
ubtripn
ubtripn's Avatar
PO bondoed the door mirror holes, can I tap and thread them?
or should I look for a different style of mirror with a different attachment place. (He also just painted the truck so I don't want to really patch it or do any metal work.)
ubtripn is offline
Old 03-16-2011, 09:42 AM   #2
lofly'a
lofly'a's Avatar
Re: PO bondoed the door mirror holes, can I tap and thread them?
"for best results", that term is important sometimes, use the factory mounting method. i assume that your truck is the 67/68 in your avatar so the the factory mirror components will look like the pics below. the backing plate is the threaded mounting point and goes inside the door. drilling and tapping the door metal IMO is not the way to go (not thick enough), especially if filler is in this area. so from inside to outside you will have the backing plate-door-gasket-mirror, this is the sandwich called a mirror assembly that is all held together with 3 screws. most of our vendors have these pieces from $40 to $50 each. even if you use another type of mirror, use or fabricate a backing plate, or you'll be tightening or reinstalling mirrors often
-02 avalanche (daily driver)
-66 gto ragtop 389/400 (garage queen, hand-me-down from dad)
-72 Tribute Trans Am (6.0LS/T56 6-speed) in progress
-2003 YUKON (Wife's)
-71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain)
-48 3100 SWB - 12/31/23 LONG TERM Project
lofly'a is offline
Old 03-17-2011, 05:20 PM   #3
68chevyLQ4
68chevyLQ4's Avatar
Who sells the backing plates?? I have the same issue with my truck.. Want to put the stock round mirrors back on
68chevyLQ4 is offline
Old 03-17-2011, 06:15 PM   #4
lofly'a
lofly'a's Avatar
i found them here:
http://www.gmcpaulstruckparts.com/Exterior.htm
or you can make your own as i did with a piece of 1/4" flat bar drilled and tapped.
lofly'a is offline
Old 03-18-2011, 09:29 PM   #5
Daddy Brim
Daddy Brim's Avatar
I got mine, mirrors and backing plates from classicparts.com very easy to install.
Daddy Brim is offline
Closed Thread
