05-07-2011, 01:48 PM | #27 |
Devil's in the Details
Re: New Guy, Old Suburban
Thought I recognized those tell-tale pack rat 'leavings'.
Looking nice and clean now.
'70 K10 Suburban - TBI 454, 4L80E, NP241C, Dana 60 & 44 - The 10+ Year Project Thread Datsun 240Z, 510 2 door and an old Honda motorcycle |
05-07-2011, 05:32 PM | #28 |
Cleaned up really great!
1969 C10 Suburban 350 1963 Falcon gasser 464 BBC 1946 Austin 327 SBC gasser |
05-07-2011, 07:10 PM | #29 |
Collector of Projects
That came out nice.... looks better then mine dose on a reagualr basis....
Where in Vegas? Im up NW off Cheyenne at the 215. |
05-07-2011, 07:34 PM | #30 |
I'm South, pretty close to the Bass Pro, opposite end of town wouldn't you know!
Got the inside cleaned up this morning and it looks good too! If I find the get up and go, I'll start on the exterior once the sun gets down a bit further.
Scott S 54 Chevy Pick-Up 71 Chevy Suburban 76 FJ40 LandCruiser - 454, TH350, NP205, Ford 9" 98 Dodge Ram 2500 4X4 Cummins |
05-07-2011, 11:22 PM | #31 |
My Dad could not find the title to the Suburban, thought we were going to have to do a title search. While cleaning the interior, under the drivers seat, guess what I found! Just need to get back up to Utah or mail it then I can drive it legally anyways
The major cleaning is done, thank goodness I would much prefer turning wrenches!
05-08-2011, 12:11 AM | #32 |
what's the gauge under the dash? A tach?
05-08-2011, 12:25 AM | #33 |
The temp gauge quite working so.....
It's on my list. The tack does not work either. Electrical repairs start tomorrow.
05-21-2011, 01:05 PM | #34 |
that truck is too clean to take apart/mod. i'd say just do the needed touch ups and drive the thing! i'm diggin' that funky vintage paint job!
05-22-2011, 02:22 AM | #35 |
Thanks capev86, my thoughts exactly!
I got the electrical manageable , all gauges are working except the temp, just have not got to it since the aftermarket one is working. I got a temporary registration, been getting it ready to be smoged, plugs, wires, distributor cap, rotor, oil, filter, fuel filter and rebuilt the carb, all today. I'm beat but she is running like a scalded ape, smog should be a snap!
05-22-2011, 10:13 PM | #36 | |
05-22-2011, 10:19 PM | #37 |
Yep.... Crazy Nevada smog laws. I just had to smog my '68 a few weeks ago.
Eric '68 C20 Suburban, Bagged with Suicide 3rd Door, and Loaded with a 396 - Under Construction http://67-72chevytrucks.com/vboard/s...d.php?t=403690 |
05-22-2011, 10:28 PM | #38 |
I think 1967 is the cut off year. Just a way for DMV to make money it has to be done every fricken year. Whats worse about five years ago Diesels had to start being smoged, in order to smog a diesel you have to find a testing facility with a dyno.
05-23-2011, 09:44 AM | #39 |
We have to smog test 1975 and later cars, but it's all done by state owned facilities, no private checks. Every 2 yrs, and it's not a problem for newer cars most the time. Fortunately my wife has the only newer car. My 3 cars are 1946, 1969, and 1971, so I don't do it at all.
05-25-2011, 01:24 AM | #40 |
Failed smog today, carburetor a little rich...what a pain.
I'll try leaning it down and see what happens, luckily I have a pretty good assortment of metering rod and jets!
Scott S 54 Chevy Pick-Up 71 Chevy Suburban 76 FJ40 LandCruiser - 454, TH350, NP205, Ford 9" 98 Dodge Ram 2500 4X4 Cummins Last edited by salvo; 05-25-2011 at 01:24 AM. |
05-25-2011, 10:26 PM | #41 |
careful with leaning it out. don't run smaller jets than it was supposed to have. stupid ethanol crap they sell us now makes for leaner running. my 72 cb350 is having problems with that due the dinosaur "piss" we are getting. had the top end redone with port and valve work and it ran fine afterwards (still had regular gas back then), so i know its the gas mucking it all up now.
they stopped doing smog checks in maine many years ago. and i will be banging on every (state) government door the moment they get the bright idea to re institute it. i was ready to cry rape when they bumped the inspection price from $6 to $12. if it is old enough not to have a catalytic converter it should be exempt! Last edited by capev86; 05-25-2011 at 10:32 PM. |
05-26-2011, 01:54 AM | #42 |
Thanks for the heads up capev86, I'm hoping the next size up on the metering rods will do it. At least it's only takes a few minutes to do it, I'll have to buy the size I need, just don't have the right ones in my assortment.
06-08-2011, 01:37 AM | #43 |
Just an update, the Burb is licensed and I bought new shoes for her too! Been driving the snot out of it, brings back a lot of good memories
Time to lower the suspension! Trying to figure out the best way to go? 2.5 drop spindles for sure, maybe another inch with lower front springs and air bags in the back or all fours? Any input would be great, I do want to be able to tow, so I really don't care to C-Notch the frame, I have a boat and car trailer that will be used allot. Coming along!
06-08-2011, 10:41 AM | #44 |
Wheels look good! Perfect for representin' Vegas in style.
Im in the process of taking my lowering springs off, and installing bags. So let me know if you're interested. 3/5 drop, only on the truck for 500-600 miles. Posted via Mobile Device Posted via Mobile Device
06-08-2011, 11:32 AM | #45 |
Thanks Eric, I will send you a PM
06-10-2011, 12:05 AM | #46 |
Junior Member
Looks great.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
06-13-2011, 12:33 AM | #47 |
Cleaning is officially over! With 40 years of old grease, oil, mud and road grime on the undercarriage, I started cleaning with a scraper...it would have taken forever! A good friend graciously offered me his lift and power washer, I spent two full days on it and it turned out great, about as close to a frame off the burb is going to see!
Here is a picture of the front a-arm, could not even see zert fittings! Here are a few after the power washer did it's magic. Lacquer thinner & break cleaner bath, 10 cans of undercoat and 8 cans of rustolium. I also needed 1/2" spacers for the rear wheels and could not find 1/2 inch longer studs, luckily I have a lath in my garage and turned down some over-sized studs. AIR BAGS NEXT WEEKEND
06-13-2011, 12:53 AM | #48 |
Nice.
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
06-24-2011, 02:45 PM | #49 |
Hey guy's I started bagging the Suburban last weekend and posted my adventures over in the Suspension Forum.
http://67-72chevytrucks.com/vboard/s...62#post4753562 The front is done and I will update the post once I get the rear done!
06-26-2011, 10:55 PM | #50 |
Just got the suspension done! I'm so happy to have that job over with
The rear axle hits the exhaust hump if I try to lower the rear were I want it, I'll have to get the exhaust pipe re-worked to set the stance that I want. It's getting pretty close even without the exhaust rework! Handles fantastic also.
