Old 05-08-2011, 07:31 PM   #1
67Step
67Step's Avatar
Question about Ride Height
When I went to buy this truck the guy had 20 inch rims on it and I didnt like them. So he pulled them off. I put these wheels and tires on it this past week. I am wondering if someone raised the front of this truck. It has a small block in it but the front end sits higher than the back. How would you all suggest I lower it? Springs or drop spindles? Thanks in advance. I am attaching a picture so you can see what I mean.
[IMG][/IMG]
1967 Chevy Shortbed, 454 CI, 700R4, currently work in progress. Check out the build up at http://www.cardomain.com/ride/2933497/1.
http://67-72chevytrucks.com/vboard/s...d.php?t=264458
1956 Chevy 3100 4x4 Stepside Truck. Sitting on Tahoe frame with LS motor.
67Step is offline   Reply With Quote
Old 05-08-2011, 07:38 PM   #2
87 chevy silverado
Re: Question about Ride Height
it is raised in the front
87 chevy silverado is offline   Reply With Quote
Old 05-08-2011, 07:41 PM   #3
Pop's C-10
Pop's C-10's Avatar
If tha springs are stock in tha front..pull em..chop a coil off & call it done..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 05-08-2011, 07:43 PM   #4
lilpoindexter
lilpoindexter's Avatar
Take a look in the lower A arm, maybe there's a spacer in there or something.
lilpoindexter is offline   Reply With Quote
Old 05-14-2011, 04:03 PM   #5
67Step
67Step's Avatar
No spacer in them.
Old 05-14-2011, 04:04 PM   #6
67Step
67Step's Avatar
Hey Pop's tell me the easiest way to cut that coil spring please. Thanks.
Old 05-14-2011, 04:28 PM   #7
bluex
bluex's Avatar
I would check the rear to see if something has been changed there. If you measure from the body line to the fender lip you will see the rear is longer. GM did that to keep the gap between the tire and fender looking the same even though the rear was higher (I guess). Either way a popular mod for these trucks is to lower the front fender so its the same as the rear.
My guess is you have weak rear springs or something has been done there. As far as the drop, I did spindles. Rides better (IMO) and lets you keep stock shocks. I did a shackle/hanger combo in the rear, but I'm about to replace it with a flip kit.
As far as cutting a coil, I believe the best way to do it is with an angle grinder. Do not use a torch...
bluex is offline   Reply With Quote
Old 05-14-2011, 04:40 PM   #8
85gmcguy
Plays with trucks
85gmcguy's Avatar
I did spindles then went back later and cut one coil. If I did it over I'd do both at the same time. Just be careful on wheel clearance with spindles, trimming lower control arm may be required. On the rear a flip kit is the only way to go IMHO. "C" notch may be optional, depending on how you plan to use the truck. And +1 on the angle grinder (or cut-off wheel). Torch is a no-no.
Gary
My Dad's Old Truck
1985
85gmcguy is offline   Reply With Quote
