05-08-2011, 08:46 PM | #1 |
60's truck with 70's front crossmember questions??
i have a 63 longbed c20....will continue to update build as progress happens...i picked up a 75 and later front end from a c10 suburban...i ordered drop spindles and bags for front....questions:
-does any one have this set up with pics? -if not how low do you pro's think the truck will get aired out? -if i want the cross member to lay on ground will the lowers need to be cupped? thanks for the help Last edited by defgone; 05-08-2011 at 09:09 PM. |
05-08-2011, 09:09 PM | #2 |
Re: 60's truck with 70's front crossmember questions??
I have a setup out of an 83 in my 65. With 20" wheels the front cross member is 2" off the ground with the bags dumped. My lowers are not cupped. What limits mine is the inner fenders. There is lots of information on this swap in the suspension section.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
05-08-2011, 10:50 PM | #3 |
Post up the tire height (or size) when you reference a wheel diameter so that the info being shared can be interpeted accurately.
05-09-2011, 02:05 AM | #4 |
Got a 62 with 78 front susp drop spindles and bags no lower cups actually the lower a-arms hit before the crossmember touches i recommend dropmember I'm gonna go dm next yr G7815 Bias Plys 28.5 in tall
05-09-2011, 07:42 AM | #5 |
My Suburban is bagged 2.5 spindle 1 5/8" tall lower bag cups Slam SS7 bags. the front arms are at least 2" from hitting. 255/60/15 tire on 6.5" van rallys. I can roll aired out and still have full steering. which I like if a bag or line ever let me down.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
05-09-2011, 08:59 AM | #6 | |
i'm trying to figure out if i want to attempt to z the front when i do this swap or if i will like the look of it with the simpler install until i can afford a front drop member |
