Old 05-11-2011, 10:51 AM   #1
Clyde65
Clyde65's Avatar
LSx Tach output? 4Cyl or 8?
I cant remember what it is and am putting a tach in soon.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-11-2011, 11:49 AM   #2
raic65
raic65's Avatar
Re: LSx Tach output? 4Cyl or 8?
I used the 4cyl configuration on my tach.
raic65 is offline   Reply With Quote
Old 05-11-2011, 12:51 PM   #3
Clyde65
Clyde65's Avatar
yours is wired right from the PCM?
Clyde65
Rebuild of Clyde
support our troops!
Old 05-11-2011, 12:55 PM   #4
raic65
raic65's Avatar
Yup. Speartech reworked the harness for me. I recall reading on a forum, it may be necessary to add a take up resistor. I did not and everything works correctly.
Old 05-11-2011, 01:18 PM   #5
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
It can be changed in your tune, so a call to your tunner may be in order. If it dosent work, TR65's resistor pull up thread is in the FAQ.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 05-11-2011, 01:53 PM   #6
Clyde65
Clyde65's Avatar
Thanks guys!
Clyde65
Rebuild of Clyde
support our troops!
Old 05-12-2011, 12:01 AM   #7
ls1nova71
ls1nova71's Avatar
If you're using a factory tach that is not adjustable for 4, 6, or 8 cylinder applications, then you'll need to have the 'tach resolution' changed in the tune from 6 to 3. (for an 8 cylinder tach) If you're using an adjustable aftermarket tach, then just set it for 4 cylinder.
ls1nova71 is offline   Reply With Quote
Old 05-12-2011, 11:01 AM   #8
Clyde65
Clyde65's Avatar
Ok, Cool, Thanks Ls1nova71.
Clyde65
Rebuild of Clyde
support our troops!
