#2976 |
Re: What did you do to your truck today?
I dropped in my motor and tranny after supper while wearing my PJs, my wife thinks I'm nuts!
65 Chevy short fleet 350 5 speed, soon to be LSX powered 65 F100 short fleet 91 Heritage softail 94 Fatboy 11 Softail Deluxe [wife's bike] 13 Streetglide http://www.youtube.com/watch?v=yMFMw...eature=mh_lolz |
#2977 |
Maiden voyage didn't end so well
#2978 |
#2979 |
looking good though man! my girl needs some love - all i seem to do is drive her to work every day lately
#2980 |
Tried to piece together parts of my air ride KIT??
![]() 1960 GMC short fleet, full frame build... http://67-72chevytrucks.com/vboard/s...d.php?t=329718 |
#2981 |
Senior Enthusiast
Reinstalled my Gaylord hard cover and gave the truck a real bath for the first time in at least 6 months. It looks pretty nice with all the crud washed off.
#2982 |
Senior Enthusiast
Today I went ahead and mounted the bed rails on the Gaylord hard cover. To the casual observer the truck doesn’t really look much different than it did when the bed was open, except now there's a very high gloss surface over the bed. Instead of using oval head screws I opted to use pan head screws with stainless fender washers coming up from underneath, with chrome acorn nuts on top. They have a machined in flat washer on the bottom which nestles perfectly into the tapered hole in the brackets. They also add a little sparkle and go with all the other bullet shaped objects on the truck.
#2983 |
Damn Mark that looks great.
http://s1299.photobucket.com/user/jb...23904108567829 |
#2984 |
#2985 |
![]() Join Date: Aug 2004
I bought some Rallye wheels and had them powder coated silver, just got them back last night and wow what a difference even though they arent mounted yet, I need two new tires and have to save a little before that can be purchased.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#2986 |
![]() Join Date: May 2009
[quote=markeb01;4674094]Today I went ahead and mounted the bed rails on the Gaylord hard cover. To the casual observer the truck doesn’t really look much different than it did when the bed was open, except now there's a very high gloss surface over the bed. Instead of using oval head screws I opted to use pan head screws with stainless fender washers coming up from underneath, with chrome acorn nuts on top. They have a machined in flat washer on the bottom which nestles perfectly into the tapered hole in the brackets. They also add a little sparkle and go with all the other bullet shaped objects on the truck.
![]() Cool as usual Mark, curious are the rails and the cover available for long fleetside's?...Vernski ![]() |
#2987 |
The speakers are 4" 2-way Kickers. I made some mounting tabs under the dash that will hold them in place. They should work well and have room for the wiper motor and vents.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
#2988 |
the gravel road i work down , needs to be graded and im not getting paid to grade the roads so mine is in the garage
#2989 |
Stripped doors in preparation for interior paint and installation of glass channels and fuzzies.
Also will be installing GMC Paul's 67-72 push on style door weatherstripping. Site member "chewychevy67" used the newer seals and said they worked well. The biggest advantage, from my perspective, is that these new seals are push on and there are no splices at corners. Here is the thread where they are being discussed: GMC paul door seals are great! We'll see how they work on my old war-horse. I kind of like the look without the ventilator... but to me the vents are part of the neat iconic features of these old trucks... they'll be staying. Last edited by lakeroadster; 05-12-2011 at 07:45 AM. |
#2990 | |
Senior Enthusiast
[quote=Vernski;4674735]
http://www.gaylordslids.com/showroom/chevy.php Unfortunately they’ve almost doubled in price since I bought mine, but they are frequently available on Craigslist for substantially less. And here is a link to where I bought the bed rails: http://www.customautotrim.com/truck-...ini/Universal/ The version I purchased is called the Bullet Mini-Tube in the 72” length. They are also available in 88” and 96” lengths. Just an fyi - Gaylord advises against attaching any accessories to the cover. I'm assuming they were envisioning wings or luggage racks which could stress the structure beyond its design limits. Also it is my understanding the inner core of the main span is some type of waffle cardboard reinforcement that could be damaged if holes were drilled allowing water into the core. The location where I mounted the rails is completely flat and about 3/16" thick of solid fiberglass. The screws are mounted using 3/4" diameter #10 fender washers underneath, and there is a rubber seal on the bottom of each stand on top. I cut away the weatherstrip under the bed cover directly around each washer so they sit flush against the bottom of the cover, and the weatherstrip is thicker than the height of the screw head so there is no metal to metal contact with the bed. Using 3/14" long #10 screws, when everything is clamped together the screws bottom out in the acorn nut threads just as everything is perfectly tight. So I don't have to worry about overtightening or having the fasteners come lose. Last edited by markeb01; 05-11-2011 at 05:43 PM. |
#2991 | |
Senior Enthusiast
#2992 |
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Well at the end of the day cut down long box sides and slammed them into a short box.....on the pro street project which is deemed ..." The project from where the devil lives".....
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[ 1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123 1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909 1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625 Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic Aluinum Radiator Dealer pm for details |
#2993 |
Do you guys have issue`s with the door seal retaining moisture at the bottom or is it just me......
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
#2994 | |
Senior Enthusiast
I had been hoping to find a brand that actually matched the density and profile of the original seals which are a bit smaller than the Chevy Duty version, but so far I haven't found any that are exactly like the originals. |
#2995 | |
#2996 |
#2997 |
Registered Loser
I played a fun game called "Try To Shut The Door Without The Brakelights Coming On!" I thought I had a short somewhere but it was just the brakelight switch needed moved in a tad.
![]() Looking good Sam! Although it would look even better driving down the road. ![]()
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
#2998 |
I got a tank and cart for my new welder. Now I have to work up the nerve to start cutting rusted parts off of the truck.
#2999 | |
Who Me?
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
#3000 |
i welded and welded and welded again and will prob do the sam tomo
