05-13-2011, 08:09 AM | #51 |
Re: '49 chevy with s-10
I made my mounts about 3.5" off the frame so that i didnt need a driveshaft tunnel. My truck wont lay the runningboards because of the wheel tire setup i'm using. At the back of the cab i've got close to 2" from the cab to the frame.
05-13-2011, 08:13 AM | #52 |
[quote=1lo67;4676891]Was hoping to be ready for Nashville Goodguys.. but i got a small job to do...money first you know.[/quote
I know what your saying about the money. Seems like i stay BROKE!! |
07-10-2011, 03:23 PM | #53 |
Interested in what you have done and don't live to far away.....what s-10 frame did you use and what all did you have to do to make it work? I'm looking at a 48 to do something similar too
Posted via Mobile Device |
07-10-2011, 03:58 PM | #54 |
At the body shop.
which s-10 chassis is it?
ive a 2000 regular cab short bed. And i like to get a 49ish body for it.
" That didnt make it any newer " " Dont antique the equipment " |
07-11-2011, 07:45 AM | #55 |
07-11-2011, 07:56 AM | #56 |
I used an '89 model standard cab longbed.(bought the whole truck running with a 4.3 for $150.00) I will say that there is more fabrication work involved than what i originally thoughtbut have friends that have subframed thier trucks and they tell me that there is alot of fab work if you go that way to. You're welcome to stop by anytime.
09-13-2011, 09:12 PM | #57 |
Just finished stripping my frame down to the metal and filled most of the holes that wont be needed Now time to get the frame and all the suspension parts painted.
09-19-2011, 11:42 AM | #58 |
LOokin GREAT!
1955 First Series Thriftmaster Blown 355 TH400, S10 Chassis,narrowed 9 Inch rear, air ride, 4 wheel disc brakes, 20s and 22s, |
09-19-2011, 04:00 PM | #59 |
09-22-2011, 08:38 PM | #60 |
Truck Junkie
This is one fine truck! I've been following your build and I must say it is basically a plan for my 52. I have the s10 frame and I'm collecting parts to get a head start. I believe you said your gonna run re6s on the front, could you take some up close pics of where you cut the pocket out to clear the bags. Any help in that area would make it easier when I start. Thanks and keep up the good work and of course lots of pics to follow along with.
Posted via Mobile Device Posted via Mobile Device |
09-25-2011, 03:48 PM | #61 | |
09-25-2011, 09:23 PM | #62 | |
you dont have to massively cut your frame. dont touch your frame until you have bags in hand. that way you dont over cut it. |
09-25-2011, 10:21 PM | #63 |
I have to agree,and so i used a set of 2600's to let me know how much to cut. I will say that re6's and re7's dont seem to ballon as much as 2500's and 2600's. I believe that no two setups are the same and when i had re6's in the front of my truck i could air it up and down with plenty of room without trimming the pocket. But like MrDude said, just wait till you can buy or borrow some bags.
09-25-2011, 10:25 PM | #64 |
I strongly recommend going with a bigger bag. I had re-6's in the front of my s10, which has a v6 and weighs a lot less than your truck will. It takes twice the pressure to get full lift than a size bigger bag, and will ride a lot better than re-6's. They take way too much pressure to lift an s10 much less a 49 chevy. You will be swapping them out in the future if you don't now, and cutting the pocket more. I would run re-7s in front and back, possibly re-8s in the back depending on clearance of your tire.
Edit: Slam bags do not balloon as much as airlift and other bags, so you can cut less and have a larger bag. |
09-26-2011, 02:36 PM | #65 |
Truck Junkie
Thanks for the input I'm sure it will save me time and headaches when I start the plan is re7s on the front and 9000s on the rear with a tri 4 bar. Thanks again!
Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device |
09-27-2011, 06:49 PM | #66 |
Super good looking truck!! What did you use to clean the frame with? Thanks Bill
09-27-2011, 07:12 PM | #67 |
Certified Car Nut
Great looking truck. Really nice.
09-27-2011, 08:54 PM | #68 |
09-29-2011, 08:15 AM | #69 |
Thought i would get a few shoots of my little helper.
09-29-2011, 09:14 AM | #70 |
Good to get them started young, frame and parts look good....Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
12-05-2011, 05:03 PM | #71 |
Finally finished painting all the suspension parts. Now time to get this thing put back together!!!
12-05-2011, 05:46 PM | #72 |
Chassis looks good....Jim
12-05-2011, 06:14 PM | #73 |
Certified Car Nut
12-05-2011, 07:37 PM | #74 |
rollinrooster, The frame looks great and it is good to see that you have a helper also. Great job.
Shannon |
12-05-2011, 09:28 PM | #75 |
How wide is your 9"? I assume it's narrowed since it's the later housing.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
