Old 07-24-2003, 01:09 AM   #1
Rob 71 chevy
Cool Quicker off line acceleration
I was told that if I put a spacer between the carb and the intake, that my power would kick in at lower rpms. Right now, I can feel it really kick in at 3500 rpms, which is higher than I would like it to be. I don't know all of the specs. of the motor, but here is what I was told when I bought the motor from a friend. 1971 350 4-bolt, 71 vette heads, 2.02's - ported/polished, 3angle job I believe, 68 Z28 high rise intake, 670 cfm Holley street avenger, 280 comp. cam, 1.5 roller rockers, not sure about pistons, 10.25 compression or 10.5 I think. And, I only run premium. I am not a real tech. when it comes to specs.
Thanks.
Rob 71 chevy is offline   Reply With Quote
Old 07-24-2003, 01:20 AM   #2
Rob 71 chevy
I forgot to mention that I have HEI. There was a spring kit that came with it. I will the change springs to see if that will help too.
Old 07-24-2003, 01:32 AM   #3
Nova_Cobra64
Nova_Cobra64's Avatar
From what I have read, spacers do help a little but I doubt it would give you much noticable bottom end. What you might need to look into is a different stall convertor and rear end depending on what your set-up is right now.
2004 Silverado - Beater
1969 GMC - In progress http://67-72chevytrucks.com/vboard/s...d.php?t=441683
2011 Aveo - Work commuter
2013 Crestliner Fish Hawk 1650 - The reason no work gets done on the project truck.
Nova_Cobra64 is offline   Reply With Quote
Old 07-24-2003, 07:18 AM   #4
70c10
67-72 Addict!
70c10's Avatar
a 280 cam is not for low end power.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 07-24-2003, 09:20 AM   #5
lukecp
Formerly yellow72custom
lukecp's Avatar
I agree...a 280 cam is not going to give you very good power off the line. What ratio is your rear axle? If you are running 3.07 gears or something close, that is your problem. With a 280 cam, you need something like 3.73-4.11 gears to make the most of your engine combo. The only other way to really get a big increase in low end power is to swap in a smaller cam, or build a bigger motor (383 stroker, or 400 small block)
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 07-24-2003, 09:27 AM   #6
SweetandLong68
Your UncleBen
SweetandLong68's Avatar
Yeah but it sounds GOOOD! Would rather have a 305 dur. hydralic. Talking about the sounds of the car gods!!!!
I would go for a rear gear change or a Nitrous KIT!!!
Slap a 100 shot on that thing. You will definetly feel the acceleration then!!!!
lata
CHRIS
68 C10 shortbed -- Street/Strip
SweetandLong68 is offline   Reply With Quote
