05-17-2011, 01:37 PM | #1 |
Pics after lowered
I have a 85 Chevy with lean problem. I have a question about the solution How much do I have to cut the passenger side spring to compensate for the 1" difference here are the measurements floor to fenders on a level surface.
Driver side Passenger side Front 28 3/8 Front 29 3/8 Rear 28 7/8 Rear 29 3/4 |
05-17-2011, 01:41 PM | #2 |
Re: Pics after lowered
I forgot to mention It has 3" spindles with 2" springs and a flip kit all new suspension bushings and shocks. Here are more pics
05-17-2011, 02:03 PM | #3 |
How long have you had the springs installed? I ask because it will take a little time for the springs to settle a bit. not sure if they will that much but it might be worth waiting a little while. Also it will help if they are cycled some too, is you truck driveable?
Also very nice truck!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
05-17-2011, 04:33 PM | #4 | |
Posted via Mobile Device |
05-17-2011, 05:26 PM | #5 |
that is what I would do and did, I put 2" drop springs in the front and it was a little wierd at first, 1K miles latter it dropped it a total of 1.25" from before because of the 40+ year old springs it had.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! Last edited by Clyde65; 05-17-2011 at 05:26 PM. |
05-17-2011, 07:35 PM | #6 |
Swap the front coils from side to side & see if the measurements change.
Did you do the rear flip kit? Were the leafs ever removed? If so, were the leaf-spring bushing bolts tightend w/the suspension extended or w/the full weight available compressing things? Try loosening these bolts & see if the measurements change. Nice looking ride!
05-17-2011, 08:54 PM | #7 |
I would wait until the truck is done, drive it and see BUT I'm not optimistic for you...I had an '87 swb that drove me nuts with 1.5" lean. I swapped springs side to side and there was no change.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
05-17-2011, 10:33 PM | #8 |
For some reason every, and I mean "every" Chevy truck I've ever owned sits a little higher on the pass. side. I always just trim the coil on that side however much it needs to level it out.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 Last edited by Painter D; 05-17-2011 at 10:33 PM. |
05-17-2011, 11:19 PM | #9 |
Thanks for the inputs guys, I have the bolts on the rear still loose they are not tight because I just mounted the bed and notice the lean problem and I might just wait and see but I was thinking on two options cut the spring on the passenger side or order another set of 3" and just use one
07-18-2011, 11:19 AM | #10 |
Well some updated information on the Lean Problem. I have been driving the truck for a while and re measure for height
Driver Passenger F 27" F 28" R 28 1/2" R 29 1/2" I thought of cutting the passenger side spring but my driver side is rubbing so I need HELP looking for a spacer to compensate for the 1" |
07-18-2011, 12:02 PM | #11 |
67-72 parts collector,…
07-26-2011, 02:27 AM | #12 |
gotta read these closer , nothing to see here move along!
ps , love the color!! Last edited by doosekoop; 07-26-2011 at 02:33 AM. |
07-26-2011, 02:28 AM | #13 |
very nice ride you got going on
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 |
07-26-2011, 09:23 AM | #14 |
I need to lower the rear about 1", I was thinking lowering blocks what do yall think.
07-26-2011, 10:21 AM | #15 |
Looks like the rear tires will rub the fender-well lip if you go any more. How much clearance is there?
07-26-2011, 10:25 AM | #16 |
Personally I think it has a great looking stance to it!
TAZ BUILDS 1966 GMC Suburban 1963 GMC Suburban Patina frame-on FOR Sale 1966 C10 Short Bed (2010-11) Monthly Updates 2015 C10 Pics with my '72 Montego GT 429/521 build 1963 Pro Street C10 back halved. Frame off I did back in 1990 Pics / Video |
07-27-2011, 07:09 AM | #17 |
07-27-2011, 07:35 AM | #18 | |
I don't think you can go any lower with those wheels. (without narrowing the rearend) I assume those are 20x10's on the back. AE shows they come in 5.5" and 6" backspacing. Do you have spacers on the rear? Different rearend housing? They should be tucked under the fenders with that much backspacing.
07-28-2011, 08:37 AM | #19 |
I have a 2" spacer but I am going to have a 1 1/2 " spacer built so I could have some clearence to tuck the rear in some.
07-28-2011, 08:59 AM | #20 |
i really like your truck.. looks sweet.
07-28-2011, 09:17 AM | #21 |
07-28-2011, 10:56 AM | #22 |
Happy to be here
Truck looks great. Tucking those tires and dropping more will be even better. What size/brand are the tires?
07-29-2011, 10:24 AM | #23 |
08-02-2011, 01:07 PM | #24 |
do you have a color name or code for that paint? Im thinking my 67 stepside might look good with that color. thanks and keep on truckin!!
08-03-2011, 01:11 PM | #25 |
