Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 05-18-2011, 10:25 AM   #1
GOPAPA
GOPAPA's Avatar
What would you do?
About 4-5 years ago I bought 2 sets of the heavy duty headlight kits from LMC. I ordered the wrong sets and got the ones for GMC's with the 4 head light hook ups..
First ,I will ask if anyone has modified a 4 headlight set up to a 2 headlight set for use in the Chevy Trucks? If so,would you let me know what you did to make it work .
What would you do?
Modify them ,,,sell them,,,or see if I can return them?
When you learn a thing a day you store up smart.
GOPAPA is offline   Reply With Quote
Old 05-18-2011, 10:56 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: What would you do?
Just curious...
Whats a heavy duty head light kit? Whats the difference between heavy duty and non heavy duty?
68gmsee is offline   Reply With Quote
Old 05-18-2011, 10:56 AM   #3
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
What all does the kit entail? I know that if the high beam lights are wired into the kit the same way GM wired the GMC high beams, then you should be able to just cut off the high beam plug. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 05-18-2011, 11:06 AM   #4
68gmsee
Active Member
68gmsee's Avatar
Did a search...
Disregard if you meant the heavy duty headlight wiring harness kit.
Old 05-18-2011, 11:32 AM   #5
GOPAPA
GOPAPA's Avatar
Here is a picture of the wiring harness I have ..It is a 100/90w high grade head lamp tune up kit .
it comes with relays and instructuons for a 4 head light wire up
this is the pkg
Old 05-18-2011, 12:49 PM   #6
68gmsee
Active Member
68gmsee's Avatar
fyi: not sure if part number has changed but LMC shows this item as being for 60-66 GMC and 60-61 Chevy.
http://www.lmctruck.com/features/cbe/CBEEL2.htm
Old 05-18-2011, 02:32 PM   #7
GOPAPA
GOPAPA's Avatar
It must fit them both as on page 69 it says it fits GMC 67-72
Old 05-18-2011, 07:55 PM   #8
sjarrett71
sjarrett71's Avatar
If you want to sell them I am definately interested!
-Scott-
sjarrett71 is offline   Reply With Quote
Old 05-18-2011, 08:58 PM   #9
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Larry... like Wes said above, you can just cut off the high beam (2-prong) connectors or trim them out. That's what I would do, if you need a harness for a Chevy. The remaining 3-prong plugs have high, low, and ground for 7" single headlamps.
Or just sell the harness. I doubt it could be returned after that much time.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 05-18-2011, 09:07 PM   #10
GOPAPA
GOPAPA's Avatar
thx Wes ,I was thinking that one could just use part of it and blank off the rest.
thx for the offer to buy them ,,but as you have read from a couple on here that I can still use them ..
[QUOTE=Stocker;4688026]Larry... like Wes said above, you can just cut off the high beam (2-prong) connectors or trim them out. That's what I would do, if you need a harness for a Chevy. The remaining 3-prong plugs have high, low, and ground for 7" single headlamps.
thx for the second opinion agreeing with Wes ,, I will put them away until I get to it.. and install them ..
Old 05-19-2011, 09:34 PM   #11
ERASER5
ERASER5's Avatar
Or just tape the extra high beam wire back. No biggie, unless you are building a show truck. The lights will not know the difference.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 05-19-2011, 10:19 PM   #12
GOPAPA
GOPAPA's Avatar
You got it ,,as I dont have show trucks .. bob it off ,,wipe some of the grease off an ol wire nut ,,screw it on the dead end and hook er up.
