Old 05-19-2011, 03:22 PM   #1
woodyjim
Oil gauge pegged out
Hey guys. The oil gauge on my '84 Silverado goes to 60 lbs. at idle. This is a recent problem. I'm running a 190 hp GM crate motor so I don't have a clue about the oil pump. I'm assuming stock? Could this be a sending unit prob? It is the original gauge. Thanks for any help. I'm at work and may not get to respond to any answers right away... sorry.
woodyjim is offline   Reply With Quote
Old 05-19-2011, 03:32 PM   #2
dos0711
dos0711's Avatar
Re: Oil gauge pegged out
Could be a sending unit problem or the engine has a high volume oil pump. Put a real gauge on it and eliminate all doubt.
1972 C-10 Cheyenne Super | Short Stepside| 454 ci | TH400 | 4:11 rear
dos0711 is offline   Reply With Quote
Old 05-19-2011, 03:37 PM   #3
parrisc19844x4_468
parrisc19844x4_468's Avatar
mine does the same at idle then goes to around 40 when running down the road.
I have a stock gauge with a high volume pump. The ideal thing would be to put in a 90lb gauge.
You could plug in a gauge right off then sending unit or just to check it , remove the sending unit and plug in a manually gauge. I replace mine electric gauge with a manually one, i never trusted the electric ones.
2017 Silverado LTZ 6.2
1984 Scottsdale K10 - 468 700r 4x4 lwb
1978 GMC Sierra Grande K15 350 Soond to be 406 th350 4x4 swb
1968 GMC 20 305 V6 good ole wood hauler.
Good Fences make good neighbors
parrisc19844x4_468 is offline   Reply With Quote
Old 05-19-2011, 09:51 PM   #4
orbot
orbot's Avatar
yep electric gauge giving you trouble.
orbot is offline   Reply With Quote
Old 05-20-2011, 08:06 AM   #5
woodyjim
Thanks for all the help guys. Where would be a good place to screw in a gauge if I wanted to get my true pressure?
Old 05-20-2011, 08:09 AM   #6
dos0711
dos0711's Avatar
Same place as the sending unit would be fine...
Old 05-20-2011, 11:01 AM   #7
parrisc19844x4_468
Yes, that is a good place. then you just as well run the copper under the dash and hook up a real gauge
