Old 05-19-2011, 06:09 PM   #26
roofingbloke
Re: just finished my front crossmember section
Looks like its the way to go,
roofingbloke is offline   Reply With Quote
Old 05-19-2011, 06:38 PM   #27
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Some guys run a rack and pinion, may be worth looking into and its a nice upgrade.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 05-19-2011, 07:23 PM   #28
SCOTI
SCOTI's Avatar
Originally Posted by smashingchuck View Post
Nope, nothing is wrong , that's what happens when you go 1.5".
Yep. The possible steering related issues are mentioned in most (if not all) of the notched/pancaked/sectioned x-member threads. Hard to miss....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-20-2011, 01:54 AM   #29
roofingbloke
From the many people who had done this, most had done a 2" section experienced steering issues, thats why i went with 1.5",
Oh well, tape measure out again, my options are, move my steering up the same 1.5" or go rack and pinion,
Thanks for the replys.
Old 05-28-2011, 03:57 AM   #30
HSkinner
K, I've been considering doing this to my 65 for awhile. is there any reason why you couldn't raise the xmember up into the frame instead of pancaking the xmemeber? I know alot of guys don't like the idea of cutting into the frame but I'd rather raise the xmember up into the frame like 5"s, welded it in and use a rack and pinion system and have better camber angles etc. I've never liked the idea of z'ing the frame. Any thoughts???
HSkinner is offline   Reply With Quote
Old 05-28-2011, 07:35 AM   #31
SCOTI
SCOTI's Avatar
At least one board member here has done something similar so it's another possibility.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-28-2011, 11:06 AM   #32
roofingbloke
I am now going to take a 1.25" section from the chassis & then raise the steering so its in the same location for the steering issues, it should work out to be a very cost affective way of lowering the front end of the c10,
Old 05-28-2011, 05:50 PM   #33
Scot_Douglas
Scot_Douglas's Avatar
Outstanding. Keep us updated!
1964 C10 - sold to chris1044
1966 C10
Build 'Fread
Scot_Douglas is offline   Reply With Quote
Old 05-28-2011, 11:34 PM   #34
HSkinner
SCOTI, who was it?
Old 05-29-2011, 01:37 AM   #35
SCOTI
SCOTI's Avatar
SCOTI, who was it?
http://67-72chevytrucks.com/vboard/s...ht=tandem+axle
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-08-2011, 04:22 AM   #36
love my 72
love my 72's Avatar
Originally Posted by roofingbloke View Post
I have done a test fit, the steering arms hit the crossmember, i am thinking that the power steering box is an aftermarket item and may have been fitted to far back,
Just thinking out loud here:
could the steering issues be solved by moving the steering box and related components one inch forward, then adding one inch to the steering shaft?
51 Chevy 3100 Deluxe Cab(SOLD)
65 **stang 6cyl
70 C10 Long Bed Fleetside(1st truck,thanks Dad![SOLD])
72 C10 Short Bed Fleetside
73 Blazer 2WD Catalina Blue White Top(Needs Love)
73 Blazer 2WD Work in progress LT1/4L60E
83 Grand National (SOLD)
94 Blazer K1500 Silverado (SOLD)
96 Impala SS All original (NEXT IN LINE 2 B SOLD)
99 Tahoe 2DR, 2WD
love my 72 is offline   Reply With Quote
Old 09-08-2011, 09:49 PM   #37
jmedero
jmedero's Avatar
ok see if you can follow me here. I have a 1.5 sec xmember that I am thinking of using. What if you take the upper and lower control arms and move the ball joint forward an inch? This would fix this and also move the wheels up and inch. You might have to grind a little on the xmember to clear but I dont think it would be that much.
What do you guys think?
As far as mounting the rack I wonder if there is a front steer unit that works like the rear steer on the Pontiac sunfire. It can be mounted closer to the driver side of the frame. This makes routing shaft and clearance issues down to a minimum. Any feed back?
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 09-09-2011, 12:35 PM   #38
Rochlow
My question is can you section a crossmember more than 1.5, if you use a rack and pinion without any major issues?
Rochlow is offline   Reply With Quote
Old 09-09-2011, 12:57 PM   #39
SCOTI
SCOTI's Avatar
Define 'major'? Custom installation of a R&P set-up & sectioned x-member would be considered 'major' by most (all?) on this site....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-09-2011, 01:14 PM   #40
Rochlow
For instance.. Let's say I "notch" the crossmember 2-3" under the frame rails. Then, use no-limits bolt in rack and pinion.
I know the frame will need to be notched for the rack, the spindles reemed out for the tie rods and the motor mount shorten or dropped..
That's the route I was looking at. Also I was think of moving the whole crossmember forward 1" to center the wheels in the wheel wells..
Not sure if this is an option..
Old 09-09-2011, 02:53 PM   #41
SCOTI
SCOTI's Avatar
Hard to sat w/o trying. I will say to watch that oil pan. 2-3" is going to leave it hanging awful low (vs the x-member). If you raise the drivetrain, that will add the the amount of planning/work.
Porterbuilts Dropmember get's you there much easier....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-09-2011, 03:08 PM   #42
Rochlow
Yea.. I hear ya. I guess I better just save my pennys and get one later on down the road..
Thanks for the advice, Scoti and sorry to Hijack the thread.
Old 09-09-2011, 03:40 PM   #43
kieth
kieth's Avatar
I'm more interested in whats going on out back, I've seen a rack and pinion before.
I'm with you, that looks like a ?explorer independant rear suspension ???
i thought of that and wondered why no one would use it.
kieth is offline   Reply With Quote
Old 09-09-2011, 03:43 PM   #44
Scot_Douglas
LOL, take a scroll through my build thread for what I experienced with a 2" section.
1966 C10
Build 'Fread
Old 09-09-2011, 03:56 PM   #45
Scot_Douglas
That's dam-near what I did, but I used rod ends (without moving crossmember forward)
While I agree Porterbuilt's dropmember would be easiest, Sectioning the crossmember DOESN'T change your crossmember-to-oilpan clearance. If you think about it, you leave the portion under the engine in the stock location and RAISE everything else around it. No change to motormounts or oilpan clearance:
Here's a good shot showing the stock motormounts in place:
Take a look-see in my build thread: It's a somewhat modified 1993 Ford T-bird SC IRS. They can be had for cheap and I wanted to shorten my wheelbase a bit (explained in my build thread) - was much cheaper than building a proper 4 link ( I didn't want to mess with moving the entire stock suspension forward)
1966 C10
Build 'Fread
Old 09-09-2011, 04:05 PM   #46
SCOTI
SCOTI's Avatar
Re-read what I said.....
....I will say to watch that oil pan. 2-3" is going to leave it hanging awful low (vs the x-member).
I'm saying to watch the oil pan clearance w/mother earth; not the x-member. If you section the x-member too much, the oil pan sump WILL be hanging below the x-member & could be the 1st thing that will come in contact w/the ground depending on the depth of the sump.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-09-2011, 04:38 PM   #47
Rochlow
Well, I might take the measuring tape out and do some thinking..
Old 09-09-2011, 05:42 PM   #48
Scot_Douglas
I'll take my chances, thank you.
1966 C10
Build 'Fread
Old 09-09-2011, 06:11 PM   #49
SCOTI
SCOTI's Avatar
Good for you.
For everyone else but you, I would recommend to verify this concern before going through the effort of raising the x-member more than 1.5".
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-09-2011, 07:16 PM   #50
Scot_Douglas
Good for you.
Har dee har har
1966 C10
Build 'Fread
