Old 05-19-2011, 11:25 PM   #51
oldman3
oldman3's Avatar
Re: Jimbo's 67 Long bed step side build
Inside roof tacked to header, then relieve cuts in the top made, bent down and then welded.
oldman3 is offline   Reply With Quote
Old 05-19-2011, 11:27 PM   #52
oldman3
oldman3's Avatar
Section all welded, ready to do next section. Had also removed the running lights on the roof and will be patched later.
Old 05-19-2011, 11:29 PM   #53
oldman3
oldman3's Avatar
Just showing how the top is starting to flow to the windshield. Will have to wait and finish the center section, when body is off frame, can't reach to good.
Old 05-19-2011, 11:30 PM   #54
oldman3
oldman3's Avatar
Went back and added filler pieces to the door opening, to have a better gap.
Old 05-19-2011, 11:33 PM   #55
oldman3
oldman3's Avatar
New power brake booster and MC came in. Installed to check fit (came from CPP).
Old 05-19-2011, 11:37 PM   #56
oldman3
oldman3's Avatar
Pic 1 New cowl hood installed, not to bad will need some adjustment.
Pic 2 New rear fender installed to replace the old spare tire fender. This is a 68 with the side marker, which will be modified and a gas fill door installed.
Pic 3 Another view.
Old 05-19-2011, 11:41 PM   #57
oldman3
oldman3's Avatar
Pic 1 Going to install one piece side windows. So I removed the vent windows, etc.
Pic 2 This bracket needs to be removed.
Pic 3 Here it has been removed. Will finish the install when the kit arrives.
Old 05-19-2011, 11:42 PM   #58
oldman3
oldman3's Avatar
Hope you enjoyed today's post, see you tomorrow.....Jim
Old 05-20-2011, 06:58 PM   #59
oldman3
oldman3's Avatar
Pic 1 New left rear fender, side marker cut out and new gas filler door installed (Hagan).
Pic 2 Close up view.
Old 05-20-2011, 06:59 PM   #60
oldman3
oldman3's Avatar
Front end all removed, you can also see new front stabilizer bar.
Old 05-20-2011, 07:00 PM   #61
oldman3
oldman3's Avatar
Starting to work on rear fenders.
Old 05-20-2011, 07:02 PM   #62
oldman3
oldman3's Avatar
Pic 1 Right rear fender, needs lots of TLC, cracked at stake pocket area.
Pic 2 Right rear fender stripped, before doing repairs.
Old 05-20-2011, 07:05 PM   #63
oldman3
oldman3's Avatar
My son grinding down the welds across the back of top.
Old 05-20-2011, 07:07 PM   #64
oldman3
oldman3's Avatar
Here you can see the welding up of the seam at the back of top, ready to do next section.
Old 05-20-2011, 07:09 PM   #65
oldman3
oldman3's Avatar
Pic 1 Here I'm cutting out bad section in the rear fender.
Pic 2 New patch piece ready to install.
Old 05-20-2011, 07:12 PM   #66
oldman3
oldman3's Avatar
Pic 1 Need to do a little finer grinding on the welds of top.
Pic 2 Welds dressed on back of top, holes filled for the running lights, all paint stripped off top of cab.
Pic 3 Another view.
Old 05-20-2011, 07:15 PM   #67
oldman3
oldman3's Avatar
Pic 1 Checking out the inside of cab, and floor.
Pic 2 Right side will need pieces cut out and repaired.
Pic 3 Left side in worse shape, but fixable.
Old 05-20-2011, 07:17 PM   #68
oldman3
oldman3's Avatar
Pic 1 Here most of the cab and doors have been stripped.
Pic 2 Bad pic, but working on the pass. side.
Old 05-20-2011, 07:18 PM   #69
oldman3
oldman3's Avatar
Well, that's it for today. Tomorrow comes quick.
Old 05-21-2011, 08:18 PM   #70
oldman3
oldman3's Avatar
Today we start on rear fenders.
Pic 1 Inside of rear fender, after getting rid of tar, ready for blasting.
Pic 2 Another shot.
Old 05-21-2011, 08:19 PM   #71
oldman3
oldman3's Avatar
Blasted and coated with encapsulator paint.
Old 05-21-2011, 08:21 PM   #72
oldman3
oldman3's Avatar
Pic 1 Found a rust hole at front of cowl.
Pic 2 Patched
Pic 3 Better pic.
Old 05-21-2011, 08:24 PM   #73
oldman3
oldman3's Avatar
Pic 1 Gas filler area to be covered.
Pic 2 Putting in patch piece.
Pic 3 Ready for welding.
Old 05-21-2011, 08:26 PM   #74
oldman3
oldman3's Avatar
Pic 1 All welded in
Pic 2 Another view, a little more clean up and then ready for filler.
Old 05-21-2011, 08:27 PM   #75
oldman3
oldman3's Avatar
Jimbo the owner, stripping paint from bed.
