Old 05-21-2011, 11:16 PM   #1
Scooterr
Putting plugs in a 5.3
This is the first time Ive ever worked on an alum head(surprising seeing how many engines Ive built)
Im a little worried about damaging the head since I have no idea if I can trust that the old owner put anti seize on the plugs or not...could it help any if I sprayed some pb blaster on the plugs and let it sit for a little bit before giving it a shot??
Or should I just make sure its cold and cross my fingers?
Sorry, I know this is a stupid question to most of you.
smoke:2001 Silverado 1500
HD tranny cooler
285-75-16 E range Hankook M/T's, Helper springs, Trailerbrakes, Toolbox(with every tool ya need), Mudflaps, etc..
Its the farms mobile work shop:
Scooterr is offline   Reply With Quote
Old 05-22-2011, 10:02 AM   #2
truckdude239
truckdude239's Avatar
Re: Putting plugs in a 5.3
well i change alot of these out and never had a problem don't have to be changed till about 100k and the factory don't normally use anti seize and they come right out, be sure to use a good set of ac delco plugs like platinum or better
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 05-22-2011, 12:47 PM   #3
Scooterr
Changed them this morning, after some interesting pops and crackles from the NGK plugs, all is good.
HD tranny cooler
Old 05-22-2011, 02:23 PM   #4
truckdude239
did you take ngks out or put them in?
David fuller
2000 Tahoe 5.3l 378
Old 05-22-2011, 05:21 PM   #5
Scooterr
Took ngks out, put AC Delcos in..those pos ngks were soo burnt out Im surprised it ran
HD tranny cooler
Old 05-22-2011, 08:37 PM   #6
Boog
laying low
Boog's Avatar
After having ruined threads in small engine heads before and having to use helicoils to save them when it came time to change the plugs in my LS engine I wasn't taking any chances. I waited until overnight to change them and used antisieze going back in. Helps lube the threads and maybe prevent them from gawling next time they come out. Cheap insurance.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
