Old 05-22-2011, 09:39 PM   #1
Red68
Red68's Avatar
Installed tach now temp gauge is off
Drove my truck around yesterday and it ran great. Took my dash out last night to install my new factory tach and when I took it out today the temp gauge is reading hot!!! Can't imagine anything happen to the engine over night. Thinking it is something with the temp gauge. Any thoughts on whatnthe problem might be?
1968 C10 LWB 327 bored 40 over, RHS heads, KB pistons, Eagle rods, Edlebrock carb & intake
1968 C10 flatbed 307 w/ 4 spd manual (dads old ride)
1936 1/2 tn pickup, 400sb 350 turbo (partially restored)
1949 1/2 tn, needs complete restore (future project)
1969 Chevy impala 4 dr no post (wifes future car)
2010 GMC Serria 4x4 crew, leveling kit
Red68 is offline   Reply With Quote
Old 05-23-2011, 02:22 AM   #2
cppursell
cppursell's Avatar
Re: Installed tach now temp gauge is off
I replaced my idiot lights with instruments and the temp gauge always gave me trouble until I bypassed the original wiring harness and routed a wire right from the sensor to #6 connector.
http://www.gmcpauls.com/Tech%20Tips1.htm
cppursell is offline   Reply With Quote
Old 05-23-2011, 07:23 AM   #3
JimKshortstep4x4
If the green wire to the temperature sensor is disconnected then the dash unit will read hot. To test the circuit ground the green wire with the key on. If the gauge reads cold then the wire is good.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 05-24-2011, 10:16 PM   #4
Ryan Hubbard
Also if you have a bad ground for your dash panel, it can cause the temp gauge to read high.
Ryan Hubbard is offline   Reply With Quote
