Old 05-23-2011, 07:15 PM   #1
irving216
1979 c10?
i just bought a 79 c10. its actually a 4wd dually stepside c10. everything you can want in a c10 right? ha welt, im not too much into trucks but if i was ever to buy one it would be this body style. the dually and 4wd was a plus. now im not big into trucks, i was actually looking for a el camino for 2 years before coming across this deal. i hope you see where im going by talking about the elco. i would like to lower this truck, at least 2'' front and 4 rear. least then i wont have to get ***** steps for my girl. ill post pictures soon and all but i was just wondering for the time being. thank you
irving216 is offline   Reply With Quote
Old 05-23-2011, 07:52 PM   #2
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: 1979 c10?
4x4 you say? Stepside dually you say? So that'd be a K30 at least, not a C10. Pics please.
Is a PITA to lower a 4x4 really, unless you're planning on making it a 2 wheel drive.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 05-23-2011, 07:54 PM   #3
irving216
Re: 1979 c10?
well how much of a pain is it? and yesss step side dually i do say and i dont want to make it two wheel drive though it seems so much less fun to say i have a 2wd lowered dualy then a 4wd lowered dually ya know? ha
Old 05-23-2011, 08:05 PM   #4
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: 1979 c10?
In line for pics.....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 05-23-2011, 08:37 PM   #5
irving216
Re: 1979 c10?
Old 05-23-2011, 08:41 PM   #6
irving216
Re: 1979 c10?
dont make fun of my paint job, we were drunk and ran out of spray cans. ill have more pix later.
Old 05-24-2011, 01:20 AM   #7
DetroitDan
DetroitDan's Avatar
Re: 1979 c10?
that is wicked cool! I certainly wouldn't lower it, I'd lift it before I did anything. You're just going to give up clearance and suspension travel if you start trying to drop it. I'd like to see it with dually hubs and matching wheels in the front, that's be sweet.
I'd say either get the ***** steps or get a more athletic girlfriend.
1982 Chevy K30 CCLB fleetside. Formerly a cab and chassis, now a fleetside dually with the rear wheels tucked underneath. 454/th400/np205/C14/D60, 6/4 inch LIFT, not drop.
DetroitDan is offline   Reply With Quote
Old 05-24-2011, 01:26 AM   #8
DetroitDan
DetroitDan's Avatar
Re: 1979 c10?
And as noted above, a C10 designates a 2wd half ton. your truck was a half ton at one time because it's a shortbed (or it was cut down but I doubt it). Probably was a K10, and someone jsut swapped 8 lug axles under it for beef, and because they had one or just for the heck of it slipped the dual rear wheel rearend under it. Doesn't look like a dually pickup axle, not wide enough, so probably a cab & chassis Corporate 14 bolt like mine.
Old 05-24-2011, 01:27 AM   #9
bigblock73
yeller
bigblock73's Avatar
Re: 1979 c10?
That thing is cool, can you take a better, non blurry pic, so we can see it more claerly?
bigblock73 is offline   Reply With Quote
Old 05-24-2011, 07:40 AM   #10
rcbildr
rcbildr's Avatar
Re: 1979 c10?
That looks like a bad a$$ truck. Could you post up more info on it?
The cheapest and easiest way to make getting in to that truck easier is by installing steps. Lowering a 4x4 can be done, but IMO that kinda defeats the purpose of having a 4x4. My friend has an 85 4x4 burb that was lowered but he quickly changed that...he told me the the PO of his burb was really short. Anyways, I just installed a pair of the Smittybuilt tube steps for my 85 diesel burb and my girls like them a lot better then the other type of step avaiable. I lucked out and found my steps in a local junkyard.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 05-24-2011, 04:03 PM   #11
irving216
Re: 1979 c10?
im at work right now so no pictures ATM. but, as far as what the truck was, i picked it up on the lift the day after i bought it and noticed something i didnt see before i bought it... the fram has been cut and welded. so our theory here at the shop was that someone might have taken a 1 ton rear frame and welded her to a c10 front. then installed a front diff assembly and such. its got a dana 44 front, and a 14 bolt rear. havent goten to take the wheels off yet to see what the deal is with the dually. im assuming its not a real dually obviously. kid i bought it off of said its a 68 camaro 350 but im very doubtful on that. still havent coded the numbers off it yet. it is a 4 speed with creeper though. ill post some more info later and much pictures.
Old 05-24-2011, 04:17 PM   #12
motornut
78K & 79C Jimmys
motornut's Avatar
Re: 1979 c10?
cool truck
need some more pics
and of the cut too.
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 05-24-2011, 04:54 PM   #13
Pop's C-10
Pop's C-10's Avatar
Re: 1979 c10?
that is a neat combo
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 05-25-2011, 09:41 PM   #14
irving216
Re: 1979 c10?
sorry didnt get a pic of the cut. im pulling the motor ATM. she was tired when i first got it but today on the way home from work she started geting a knock. soooo im debating if i want to get a 350 vortec and drop it in, or if i want to take my 305ho and put it in. im leaning towards the 305 because of the electric fuel pump i would need to get with the 350, i dont feel like seting that up. hope yall enjoy. MIND YOU THE AC WAS TAKEN OFF RIGHT BEFORE PICTURES haha
Old 05-25-2011, 09:42 PM   #15
irving216
Re: 1979 c10?
P.S yes that is a camaro stearing wheel i stole it out of my camaro for the temp use haha
Old 06-03-2011, 11:53 PM   #16
irving216
Re: 1979 c10?
ahhh so my engine started knocking a week or so ago, so i started working on my 305ho i had sitting in the garage. im doing head gaskets for the hell of it. so in the mean time, i bought her a new dress up kit. ill probably pull the motor in the truck and re do that, see which i like more
Old 06-05-2011, 10:27 PM   #17
irving216
Re: 1979 c10?
final product.
Old 06-05-2011, 11:12 PM   #18
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Re: 1979 c10?
My buddy has one like that too.
If it aint square, I don't care.
84 C35 CC Dually Project log...
http://67-72chevytrucks.com/vboard/s...d.php?t=414892
1tonchevy is offline   Reply With Quote
Old 06-05-2011, 11:18 PM   #19
Your41Plague12
Your41Plague12's Avatar
Re: 1979 c10?
To the OP, I have three words for you. JACK IT UP. That's such a cool idea, that's just mean looking.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 06-06-2011, 03:10 AM   #20
csb#356
Re: 1979 c10?
I would die a little inside if I saw you lower that. I honestly feel it would be an embarrassment
csb#356 is offline   Reply With Quote
Old 06-06-2011, 12:17 PM   #21
irving216
Re: 1979 c10?
i feel as though lifting it is not practical, it serves no purpose but the look and off roading. neither of which im worried about. i dont want to slam it like the mexis out in cali. i just want it to be practical that if i so choose to change my gears around, i wont die when i go around a turn at 50 ha
Old 06-06-2011, 12:30 PM   #22
csb#356
Re: 1979 c10?
I don't think it would be turn any better. old 4x4s with straight axles just don't really handle well.
Old 06-06-2011, 10:10 PM   #23
Your41Plague12
Re: 1979 c10?
Exactly. To make this a 1970's 4x4 dually handle well is quite a task. You're going to have to lower it a ridiculous amount to get a noticeable effect. I'd leave it the way it is, personally. Or sell it and buy a stock truck.
Steve
