Old 05-23-2011, 08:04 PM   #101
oldman3
oldman3's Avatar
Re: Jimbo's 67 Long bed step side build
Pic 1 Grinding down the welds.
Pic 2 Installing round corners on the bed rail, used exhaust tubing 90's.
Pic 3 Welded in metal, also welded to stack pocket to make it real solid. Then weld another patch finish off the hole.
oldman3 is offline   Reply With Quote
Old 05-23-2011, 08:06 PM   #102
oldman3
oldman3's Avatar
Pic 1 Getting things set up to weld the end cap.
Pic 2 Dont' have pic showing welded, but here I'm adding filler to flat end.
Old 05-23-2011, 08:08 PM   #103
oldman3
oldman3's Avatar
Pic 1 Inside of rear fenders in epoxy primer.
Pic 2 Another view of rear fenders.
Old 05-23-2011, 08:10 PM   #104
oldman3
oldman3's Avatar
Pic 1 Inside of front fenders in epoxy primer.
Pic 2 Next day a general view before painting.
Old 05-23-2011, 08:13 PM   #105
oldman3
oldman3's Avatar
Pic 1 Painting all the outsides of fenders in epoxy primer.
Pic 2 Another view
Pic 2 Another view.
Old 05-23-2011, 08:14 PM   #106
oldman3
oldman3's Avatar
We'll stop there for today, and pick back up tomorrow.....Jim
Old 05-23-2011, 08:57 PM   #107
bollybib
bollybib's Avatar
I'm enjoying the story (even tho I don't always post to say so). Your metal sculpting skills are impressive (and the size of your shop, too). Thanx for sharing.
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
Old 05-23-2011, 10:23 PM   #108
andrewhass81
I'm loving this build. I'm working on a 69 C-20 long step myself.
andrewhass81 is offline   Reply With Quote
Old 05-23-2011, 11:38 PM   #109
oldman3
oldman3's Avatar
Thanks for the compliments. My son is helping on this build, so some of the work is his and some mine. Shop is 30X40 and at times, there isn't enough room (we all say that)....Jim
Old 05-23-2011, 11:41 PM   #110
oldman3
oldman3's Avatar
Thanks for checking out the build, glad to see more of them getting the attention....Jim
Old 05-24-2011, 01:06 AM   #111
andrewhass81
I'm building this one for my son. He's only 7, so thankfully I have plenty of time.
Old 05-24-2011, 01:03 PM   #112
oldman3
oldman3's Avatar
Be careful, time has a way of getting away from you. My son and I were going to do a build together when he was 20, he turns 40 this year and we are finally starting a build together for him. He's doing most of the work, I'm just giving fatherly advise.
Old 05-24-2011, 08:19 PM   #113
oldman3
oldman3's Avatar
Starting from yesterdays post of epoxy primer on fenders.
Pic 1 After a couple days I sprayed with regular primer(another bad pic, sorry).
Pic 2 Same
Pic 3 All in primer with a light guide coat.
Pic 4 Another view.
Old 05-24-2011, 08:22 PM   #114
oldman3
oldman3's Avatar
Pic 1 Removed the right rear cab corner.
Pic 2 Right outer rocker panel removed.
Pic 3 Here's the new patch panel for cab corner.
Old 05-24-2011, 08:25 PM   #115
oldman3
oldman3's Avatar
Pic 1 This is what we found on the right front cowl area.
Pic 2 Overall view.
Old 05-24-2011, 08:28 PM   #116
oldman3
oldman3's Avatar
Pic 1 Cut out and replaced bad section.
Pic 2 More patching done and more needed.
Old 05-24-2011, 08:32 PM   #117
oldman3
oldman3's Avatar
Pic 1 This area will be blasted and painted with encapsulator paint.
Pic 2 New cab corner and rocker panel in place.
Pic 3 Rocker area.
Old 05-24-2011, 08:36 PM   #118
oldman3
oldman3's Avatar
Pic 1 Checking gap at bottom of door and new rocker.
Pic 2 Another view
Pic 3 Made a few adjustments, cut weld and grind.
Old 05-24-2011, 08:39 PM   #119
oldman3
oldman3's Avatar
Pic 1 Put fiberglass filler in cab corner.
Pic 2 Filler on back of cab.
Pic 3 Another view.
Old 05-24-2011, 08:41 PM   #120
oldman3
oldman3's Avatar
Tomorrow we go back to the bed sides for additional mods and repairs. Hope to see you then......Jim
Old 05-24-2011, 09:26 PM   #121
andrewhass81
Originally Posted by oldman3 View Post
be careful, time has a way of getting away from you. My son and i were going to do a build together when he was 20, he turns 40 this year and we are finally starting a build together for him. He's doing most of the work, i'm just giving fatherly advise.
lol.
Old 05-25-2011, 03:28 PM   #122
Shaky
Six in a row makes it go...
Shaky's Avatar
Nice truck! Looks verrrrry familiar...
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 05-25-2011, 06:23 PM   #123
oldman3
oldman3's Avatar
Two peas in the pot, sure fits doesn't it. You have one very nice looking pickup.
Old 05-25-2011, 06:26 PM   #124
oldman3
oldman3's Avatar
Today's post will take awhile, but I think you might enjoy it.
Pic 1 Filler along top of pass. bed rail.
Pic 2 Working on the drivers bed side, adding the rounded corner on bed rail.
Pic 3 Close up, ready to add filler pieces later.
Old 05-25-2011, 06:28 PM   #125
oldman3
oldman3's Avatar
Pic 1 Installed fender on bed side to check fit, etc.
Pic 2 The old bed sides are in ruff shape.
