05-23-2011, 09:34 PM | #1 |
8848stro
cross member
Anyone know if big block crossmembers are different from small blocks?
05-23-2011, 09:47 PM | #2 |
Re: cross member
dont think so
05-23-2011, 09:55 PM | #3 |
8848stro
Re: cross member
I installed motor and tranny today and holes in crossmember did not line up!
05-23-2011, 09:58 PM | #4 |
Re: cross member
maybe the towers are diffrent some will chime in that has done the swap before
05-23-2011, 10:22 PM | #5 |
8848stro
Re: cross member
maybe i have the towers in backward?
05-25-2011, 01:47 PM | #6 |
8848stro
Re: cross member
Anybody know if engine stands are different for 2-wheel and 4-wheel drive-went to install drive-shaft and is too long!
05-25-2011, 02:25 PM | #7 |
"brand new second-hand"
Re: cross member
My truck was a small block and I changed it to a Big Block. The cross-member was not a problem-I used factory mounts. The floor tunnel was a "low" tunnel and was no problem. I did have to cut the drive shaft as it was too long. The truck came stock with a turbo 400 and I rebuilt and used it. I used gm factory engineered parts for everything to avoid any problems and it came out great. I have seen both big block cross-members and small block and know of no differences. Good Luck
Steve 69 3/4t custom camper tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c 67 Camaro 96 Impala ss-sold 04 hybrid Honda-saving gas for the blue truck!:b69: |
05-25-2011, 02:51 PM | #8 |
Re: cross member
I believe the transmission cross member is the same but, I'm not 100% sure. I would bet it has more to do with your motor mounts. What year is your truck and what year are your motor mounts?
05-25-2011, 03:23 PM | #9 |
8848stro
Re: cross member
The truck is a 69-stands are 71S-
05-25-2011, 03:59 PM | #10 |
Moderator
Re: cross member
It would help to know what motor and trans you are installing, also if it is a 2WD or 4WD truck. The x-members are the same for bbc/sbc in a 2WD truck. BBC never came in 4WD trucks, and the x-member is different in them I believe. Are you using big block mounts or small block mounts? Specifics are needed to determine what is going on.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
05-25-2011, 08:05 PM | #11 |
8848stro
Re: cross member
I am installing a 366 which was in truck with hacked up small mount stands-350 turbo-2wd,am using bb stands and mounts-it seems i can move motor forward but there is no more holes on drivers side and headers will hit lower a-frame-i think the oil pan will clear-I am just trying to do it correctly!2WD
