Old 05-24-2011, 10:45 AM   #1
Dick Dale
Excelsior, You Fathead.
Dick Dale's Avatar
2002 GMC Sierra ABS issue
My ABS goes off at slow stops on occasion. It happened yesterday pullingup to a gas pump and will happen occasionally when going to a red light or stop sign, parking spot, etc. The brakes are a few years old but I don't drive it often so they are still in good shape and the fluid is full in the MC. Any ideas?
Go Navy. The Sea Is Ours.
Budget 350 Build
http://67-72chevytrucks.com/vboard/s...38#post2264638
Dick Dale is offline   Reply With Quote
Old 05-24-2011, 11:05 PM   #2
Sillyoldman
#16876
Sillyoldman's Avatar
Re: 2002 GMC Sierra ABS issue
ttt
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 05-25-2011, 12:27 AM   #3
clinebarger
Bad/Cheap front wheel bearings or corrosion(road salt) in the bearings/wiring.
clinebarger is offline   Reply With Quote
Old 05-25-2011, 08:50 AM   #4
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
(borrowed from another post)
Condition
Some customers may comment on ABS activation at low speeds, usually below 8 km/h (5 mph). Upon investigation, the technician will find no DTCs set.
Cause
The cause of this condition may be an increased air gap between the wheel speed sensor and the hub reluctor ring due to rust and debris built up on the sensor mounting surface.
Correction
Measure AC voltage and clean the wheel speed sensor mounting surfaces.
Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in the General Information sub-section of the Service Manual.
Disconnect both the front wheel speed sensor connectors at the frame and harness.
Place a Digital Volt Meter (DVM) across the terminals of each wheel speed sensor connector.
Rotate the wheel clockwise approximately one revolution per second. The minimum reading should be at least 350 ACmV's. If the reading is less than 350 ACmV's, remove the wheel speed sensor. Refer to the applicable Wheel Speed Sensor Replacement procedure in the ABS sub-section of the Service Manual.
Plug the wheel speed sensor bore in order to prevent debris from falling into the hub during service.
Clean the wheel speed sensor mounting surface using a wire brush, sand paper, emery cloth, scotch brite, or other suitable material. Be sure to thoroughly clean the wheel speed sensor surface. There should be no rust or corrosion.
Check the sensor head to determine if it has been warped/distorted due to the corrosion build up or other causes. Check the mounting surface on the sensor head for flatness by placing it on the edge of a metal machinists scale or other suitable straight edge to measure the flatness. Check the sensor for flatness in multiple (minimum 3) positions/directions. If the sensor head is distorted, replace the sensor.
Apply (spray) two thin coats of the specified rust penetrating lubricant (corrosion inhibitor) to the complete sensor mounting surface on the bearing hub. Allow to dry for 3-5 minutes between coats. Use ONLY Rust Penetrating Lubricant, P/N 89022217 (in Canada, P/N 89022218).
When the corrosion inhibitor is dry to the touch (about 10 minutes), apply a thin layer of bearing grease to the hub surface and sensor O-ring prior to sensor installation. Use ONLY Wheel Bearing Lubricant, P/N 01051344 (in Canada, P/N 993037).
Install either the original sensor or a new one in the hub. Ensure that the sensor is seated flush against the hub. Refer to the applicable Wheel Speed Sensor Replacement procedure in the ABS sub-section of the Service Manual.
Place the DVM across the sensor terminals and recheck the voltage while rotating the wheel. The voltage should now read at least 350 ACmV's.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 05-26-2011, 10:14 AM   #5
HTX86chevy
HTX86chevy's Avatar
disconnect the sensor that leads to the rotor hub, i did it and it worked. the abs light will remain on but it sure is better than having the abs act up all the time
HTX86chevy is offline   Reply With Quote
Old 06-02-2011, 12:52 AM   #6
sjreno
There was actually a recall for trucks in the salt belt states. Same prob w/ my '00 silverado and my buddy's '04 Denali. I just yanked out the huge blue fuse for ABS, prob solved, sort of
sjreno is offline   Reply With Quote
