Old 05-24-2011, 09:23 PM   #301
my4by2
my4by2's Avatar
Re: 1977 Chevy K30 Crew Cab Build
Here's some initial fabrication shots of my side steps. Really like the hoops & step pad look!!!
They initially mounted the actual rail too low & a little too inboard so they're gonna have to move it a bit. Hopefully will get a better shot of the final position before the end of the week.
my4by2 is offline   Reply With Quote
Old 05-24-2011, 11:05 PM   #302
77BBGMC
77BBGMC's Avatar
This is a cool build!!
77BBGMC is offline   Reply With Quote
Old 05-25-2011, 09:55 PM   #303
my4by2
my4by2's Avatar
Here's the front Mile Marker hubs finally installed. They had to machine a groove inside the hub for these to work... Notice the nicely painted OE calipers & upgraded EBC GreenStuff brake pads - should stop nicely!
Old 05-25-2011, 10:44 PM   #304
jbclassix
Junk Yartist
jbclassix's Avatar
Why the groove? Snap ring?
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 05-25-2011, 11:02 PM   #305
my4by2
my4by2's Avatar
And here's the correctly "repositioned" side step bars! They're still not final welded or anything as they wanted me to Ok everything before going into that part... Think they look GREAT & there surely won't be another crew cab out there with ones like these on it!!!
Old 05-25-2011, 11:03 PM   #306
my4by2
my4by2's Avatar
Yep. These hubs originally had the auto locking style & guess it was a mid-year thing or something & the Mile Markers needed an internal groove that most later models have...
Old 05-25-2011, 11:06 PM   #307
my4by2
my4by2's Avatar
A few clearer pics of the actual mounts for these rails. Somehow doubt that I'll ever have much trouble with these getting weak or sagging on me!!!
Old 05-26-2011, 12:04 AM   #308
y5mgisi
Second Chance Program
y5mgisi's Avatar
Those do look good! And very stout too! i didnt realize the frame was so clean already!
y5mgisi is offline   Reply With Quote
Old 05-26-2011, 01:47 AM   #309
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Those steps are sweet!
Ryan
1969 Chevy milk truck
Old 05-26-2011, 04:36 AM   #310
my4by2
my4by2's Avatar
Yeah, frame has already been media blasted & powder coated just like the axles. The frame mounts for these step bars will also get added gussets before all the final welding is done.
Old 05-26-2011, 02:46 PM   #311
kikkegek
kikkegek's Avatar
I really love the side steps!
kikkegek is offline   Reply With Quote
Old 05-26-2011, 08:46 PM   #312
my4by2
my4by2's Avatar
Finally got the correct part number for the A/C condenser so it's all ordered from LMC Truck & en route. The shop will then have everything for the system other than the actual lines (which need to be custom made) & the correct o-rings for the R134a.
Old 05-27-2011, 11:08 PM   #313
my4by2
my4by2's Avatar
Duh..... Just realized that I wrote condenser & what I actually meant to write was evaporator! There were two different models used that year & they had to figure out which I needed.
1977 Chevrolet K30 LWB Crew Cab
497HP Mast Motorsports 6.0L LY6 HO engine
GM NV4500 5-speed, Centerforce clutch + NP205
D60 + 14-bolt FF w/ Eaton posi + disc brakes
Skyjacker 2.5" full spring lift w/ Nitro shocks
Custom paint + interior
http://67-72chevytrucks.com/vboard/s...d.php?t=435722
Old 06-01-2011, 11:27 PM   #314
my4by2
my4by2's Avatar
Well... For some reason Summit cancelled my order for the left hand door latches (Goodmark) - guess because it kept getting pushed back for whatever reason. Oh well, LMC Truck has them in stock, so I will just place the order with them (like I should'a done in the first place it turns out).
Old 06-01-2011, 11:31 PM   #315
MTCK
MTCK's Avatar
Summit just did the same thing today on my cold air kit from Spectre... Must be cleaning out all the back orders I guess.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 06-01-2011, 11:36 PM   #316
my4by2
my4by2's Avatar
Be nice if they'd ask ya first....
Old 06-02-2011, 12:26 AM   #317
sethv
sethv's Avatar
I like this truck! It's coming along nicely and it's going to be awesome when it's all done!!
Keep it up dude!
1981 K10 Scottsdale
305 ci | TH350 | NP208 |
60k miles
sethv is offline   Reply With Quote
Old 06-02-2011, 12:49 AM   #318
Dieselwrencher
They used to and I'm sure they got tired of people yelling at them so they quit doing it.
Ryan
Old 06-02-2011, 09:30 PM   #319
my4by2
my4by2's Avatar
Shop's telling me that the Corbeau seat brackets I bought don't fit my truck properly... They called Corbeau & they do have the correct part for my year, but think it has to do with my truck being a crew cab rather than a regular cab, so they'll just have to modify them to work in mine - not a big deal really...
Should have new pics to post tomorrow evening with any luck as well.
Old 06-02-2011, 10:31 PM   #320
y5mgisi
y5mgisi's Avatar
Probably needed to have ordered them for a suburban. Oh well. It will all work out in the end.
Old 06-02-2011, 10:49 PM   #321
luifer76
luifer76's Avatar
wow very nice work your doing on the man keep it up....
nOtHiNg LiKe ThE gOoD oLe ChEvYs....
luifer76 is offline   Reply With Quote
Old 06-02-2011, 10:49 PM   #322
my4by2
my4by2's Avatar
Well, the shop called & talked to Corbeau for quite a while - apparently they only sell one style bracket for the 73-87's.... No biggie really, seat brackets get modified & mounts changed all the time - plus the shop is GREAT at fab work!
Old 06-03-2011, 09:40 PM   #323
my4by2
my4by2's Avatar
Here's some additional pics of the side step assemblies after getting more permanent welding. Still gotta get smoothed & sent out for powder coat a little later on. Also, the bolts you see on the step pads still need to be swapped out with a button head style to match the other stuff on the truck.
Old 06-03-2011, 09:42 PM   #324
my4by2
my4by2's Avatar
The Corbeau bucket seats actually got mounted today after they modified the brackets - still gotta final weld it all & "dress it up" a bit. Can't freaking wait to be behind the wheel in these seats!!!!
Factory rear seat will be sent out after paint to be recovered to match the look of these seats, so it'll all tie in pretty well.
Old 06-03-2011, 09:45 PM   #325
my4by2
my4by2's Avatar
Here's another shot of the front hub look too. These are the wheels & tires that came on the truck when I bought - NOT the one's that will be on the finished product! Just wanted to see what the brake calipers looked like through the holes - although the other wheels have round holes & are black in the middle...
