Old 05-23-2011, 03:16 PM   #1
dgreen
what rim SIZEs
what rim sizes can i get away with 87 chevy pick up,?
dgreen is offline   Reply With Quote
Old 05-23-2011, 04:13 PM   #2
tazman87
tazman87's Avatar
Re: what rim SIZEs
10 inch rims. 295 tire. and i'm sorry but i cannot remember the spacing. but what i have is the biggest you can go without tubbing the fenders
tazman87 is offline   Reply With Quote
Old 05-23-2011, 04:15 PM   #3
tazman87
tazman87's Avatar
Re: what rim SIZEs
those are the rears of course
Old 05-23-2011, 04:18 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: what rim SIZEs
I have been told that you can squeeze a 315/35/20 on an 11" rim but you have to nail the backspace.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-23-2011, 05:34 PM   #5
dgreen
Re: what rim SIZEs
sick thanks, the only thing i dont under stand is the spacing i want to buy these rims but dont know what to do with the spacing.
http://www.summitracing.com/parts/USW-37-5850/
Old 05-23-2011, 08:39 PM   #6
bmchevy1979
bmchevy1979's Avatar
Re: what rim SIZEs
those being a 15x8 rim the backspacing on them is a little less critical and the ones you posted are about where you would want it to be
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 05-24-2011, 09:34 AM   #7
dgreen
Re: what rim SIZEs
how much back spaceing would i need ? 1/2 inch ?
Old 05-26-2011, 05:08 AM   #8
Slammed '87
Slammed '87's Avatar
Re: what rim SIZEs
That is a pretty common backspace size for those types of wheels. It is a good backspace on the front wheels if you are lowered because there will be no rubbing issues on the lower a-arms. If you run a 15 x 10 in the rear you can only lower it so much or it will rub the outer fender. I don't know if yours is lowered or if you plan to, but just thought i'd let ya know either way. Here is a picture of my old '87 GMC with similar wheels, same backspace. The fronts are 15 x 8 and the rears are 15 x 10.
If you can't rock the roads with your bumpers 1/2" off the ground, you're nowhere near low enough!
Slammed '87 is offline   Reply With Quote
Old 05-26-2011, 06:10 AM   #9
dgreen
Re: what rim SIZEs
thanks dude!
Old 05-26-2011, 06:19 AM   #10
dgreen
Re: what rim SIZEs
how much did you lower it?
Old 05-26-2011, 10:43 AM   #11
Slammed '87
Re: what rim SIZEs
The truck was lowered 6" in the front with 3" spindles and springs. The rear was lowered about 8" with a 6" flip kit, and removed two leafs 2" and had air bags. In those pictures the rear was aired up to about a 5" drop to clear the tires.
Old 05-26-2011, 11:41 AM   #12
dgreen
Re: what rim SIZEs
ok sick bc i just want to drop the ass end 2" with shackels to make it level, im just trying to fig out if i have to notch the frame or not, and ive never put bushings in idk how to go about that looks easy tho
Old 05-26-2011, 11:47 AM   #13
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: what rim SIZEs
With 2" shackles in the rear you don't have to notch the frame, just the bed. Otherwise the shackles hit the bed crossmember right above the shackle.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 05-26-2011, 12:30 PM   #14
dgreen
Re: what rim SIZEs
ok sick got any photos of were i need to notch it, thanks for the help
Old 05-26-2011, 04:43 PM   #15
joe231
joe231's Avatar
Re: what rim SIZEs
depends on the rear spring length...52" leafs you have to notch the cross sill...56" leafs you don't have to .
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 05-26-2011, 05:15 PM   #16
dgreen
Re: what rim SIZEs
what came with a 87 chevy pick up lwb 5.7 silverado?
Old 05-26-2011, 05:38 PM   #17
RandyP
RandyP's Avatar
Re: what rim SIZEs
I did not measure my leafs, but my 1987 LWB Silverado, the shackles would not fit and clear the bed, so I took them back off. They were hitting the beds cross braces.
Old 05-26-2011, 11:21 PM   #18
slugish
Slugish
Re: what rim SIZEs
Im running 275x17 on 9.5 rims --4 in bs -- & its all Ican do without rubbing.
lowered 6.5-7 in the rear. If that bs 'ing on your wheel shown is less than 4.5 in Idont think it would work unless you tubbed or rolled your fender lips
slugish is offline   Reply With Quote
Old 05-26-2011, 11:21 PM   #19
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: what rim SIZEs
Joe is correct, it depends on spring length and bed length or a combination of the two.
Articles-
"Refining Sierra"
Old 05-27-2011, 07:19 AM   #20
dgreen
Re: what rim SIZEs
ya i looked it will for sure hit my bed, any one got photos of how they cut the bed?
Old 05-27-2011, 08:13 AM   #21
bbbc10
Diggin The SquareLife
Re: what rim SIZEs
my 84 wth 15x10 wth 5" of bs an 275/60 an 6" drop.jus got enuff room to slide my hand between the lip an tire
bbbc10 is offline   Reply With Quote
