#1401 |
Re: ** YOUNG FRANKENSTEIN ** The truck Chevrolet should have built.
my goodness, I like this project, but I wont lie, I cringed a little when I found out what you did to the sub.
Susie-Honda Accord Coupe|Elisa-1968 Chevy C20 Holdin' it down in the 520
#1402 |
![]() Join Date: Mar 2010
I'm sure as soon as I post this someone will let me know why. Maybe I've been drinking too much, but why did you mask off the centers of the doors, but not the fenders?
#1403 |
67cheby
![]() Join Date: Sep 2008
i actually wondered the same thing
#1404 |
Thank God, I thought I was a little slow or something haha.
#1405 |
he was having problems aligning the molding on the fenders as there isn't a constant body line to make sure they were square to the world. I believe he knows where that line will be on the doors, and will hang the fenders to locate the white area on there later.
#1406 |
Lucky Teter at the wheel
I went round and round on where the upper molding should go on the fenders. I know where in theory, but what if the front end of the molding needs to be adjusted a quarter or half inch up or down so that it runs straight with the rest of it on the doors and bed? You can't do it because the upper molding stops about 1 inch short and leaves your paint break line showing. On top of that the molding comes to a point and so it is critical that your paint line is exactly in the middle. I just had a bad feeling that on the final assembly my front upper molding might end up running uphill or down. I am going to mount and adjust all the sheet metal and then pull a string to mark where to mount the molding on the fender, drill the holes, tape/plastic the whole truck and shoot the white on just the fenders at the end. I might be over thinking it, but better safe than sorry.
Drew YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!) The Bride is currently under the knife!
#1407 |
Exactly, you just type faster than me.
#1408 |
Liquid frustration.
A big fat run pictured, and 2 pics of a landfill worth of trash that took up residency in my fresh paint. Last pic is a shot of wet sanded with 600 grit but I need to hit it with the block and sandpaper just a tad more to get rid of those few shiny spots of trash. And if anyone is wondering, I have not re-primered, this what the blue looks like when wet sanded.
#1409 | |
#1410 |
Try misting the plastic walls and floor down with water prior to painting, also blow off parts before painting and wipe down with tack rag. You may have done these things just thought I would chime in.
#1411 |
Drew, why did all the other parts that you painted look so nice, then the last batch turns out fuzzy? Seems like alot of crap, seems like whenever that happens to me its usually my gun that has not been cleaned properly, and the new solvents are "melting" the old in the gun and blowing the lovely little chunks.
Just a thought, and remember I bought my booth at the same place you got yours!!!! Darren
67- 72 Parts collecter |
#1412 | |
Still plays with trucks
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#1413 | |||
#1414 | |
#1415 |
Here we go with some pics of the door and fender success.
#1416 |
VA72C10
![]() Join Date: Mar 2008
looking good!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#1417 |
![]() Join Date: Dec 2010
Much improved & very nice!
1977 Chevrolet K30 LWB Crew Cab 497HP Mast Motorsports 6.0L LY6 HO engine GM NV4500 5-speed, Centerforce clutch + NP205 D60 + 14-bolt FF w/ Eaton posi + disc brakes Skyjacker 2.5" full spring lift w/ Nitro shocks Custom paint + interior http://67-72chevytrucks.com/vboard/s...d.php?t=435722 |
#1418 |
![]() Join Date: Mar 2004
nice spray work
#1419 |
![]() Join Date: Jul 2010
Whatever you did this time it worked. Good Job/I'm taking notes.
#1420 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Nice and shiny ...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#1421 |
looking good man
#1422 |
Drew,
Wow!! very nice work .. NEVER to be a critic or knocking any of your work .but i was wondering why you did not locate the fuel tank filler in the rear opening of the left rear fender marker light .. Does any one know where the old link for this modification is on here ? a while back some guy on here used a filler pipe .. He put it in the rear side marker light area .. he used the filler door harware from a s-1o p/u donar i think for the hinge and door .. he was able to fill his gas tank from the rear side marker opening.. i want to do this on mine as well .. someday with a rear tank.. any way.. Your truck is awesome and you are an amazing mechanic and metal worker . a true crafsman. i cant wait to see this on the road.. GOD BLESS AND KEEP THOSE PIC.S COMING.. DANDELUXE ![]() ![]()
1969 cst swb 350/400 th . DANNY C . ["]FRIENDS DONT LET FRIENDS DRIVE F@RD$!! ![]() ![]() 1969 cst swb corvette hugger orange with 400 hp sbc I started out with nothing and i held on to it ![]() ![]() ![]() ![]() |
#1423 | |
#1424 |
Paint looks nice.
1972 GMC (PROJECT LONG OVERDUE) ![]() 1998 SWB 4WD |
#1425 |
![]() Join Date: Apr 2000
somehow didn`t see this build,from last night to now,i`m impressed.. i`d say this is one of the top 3 builds that made me say wow,since i`ve been on this site. great job can`t wait to see it completed..
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
