Old 07-26-2003, 01:04 AM   #1
apstguy
LED King
apstguy's Avatar
ATTN: Need help quick - Check engine light
I just finished installing my amp and subs and now my check engine light is on. What two pins to I short to get the codes? Where can I find the codes? I ran the power fro the sub through the firewall in the hole where all the computer stuff comes out of (uh ho). Thanks!!
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 07-26-2003, 01:18 AM   #2
apstguy
LED King
apstguy's Avatar
Come on guys! I need to know tonight! Truck drive perfectly fine but the light is on which scares me because that usually means something is horribly wrong because the computer is so brain-dead!
Tyler
2016 Chevy Spark EV
Gone: 2008 VW R32
Old 07-26-2003, 01:26 AM   #3
navybear70
hometown heroes!
navybear70's Avatar
You have a check-engine light?!? That's pretty high-tech dude. I gotta check my engine manually!
Seriously, I don't know...sorry.
2009 Silverado 2wd, 121k as of 04APR13. I love my truck 29 days out of the month. The payment is due on the 30th...
Do your duty in all things. You cannot do more, you should never wish to do less. -Robert E. Lee
"Never give up ground you've already taken." -Unknown
navybear70 is offline   Reply With Quote
Old 07-26-2003, 01:30 AM   #4
apstguy
LED King
apstguy's Avatar
I got the trouble code: 34 - A firebird site says it is the MAP or MAF sensor. WTF??? I don't have a MAP sensor or a MAF sensor! This thing is like a "Something is wrong" light. The trouble code really didn't help. Grrrr.....
Tyler
2016 Chevy Spark EV
Gone: 2008 VW R32
Old 07-26-2003, 02:02 AM   #5
apstguy
LED King
apstguy's Avatar
I have been messing with it and sometimes before I start it I get a loud fast continuous clicking (usually I get a soft slow clicking) It sounds like a normal noise that happens at about 1/4 throttle but now before I start it. It has a slower than normal idle but only barely. Since it is black outside (11pm) I can't really see anything.
Here is the sensor outlined in red:
What the hell is that sensor? A MAP sensor? I ran my hand down the vaccuum line and it is cut. Is that my problem?
Tyler
2016 Chevy Spark EV
Gone: 2008 VW R32
Old 07-26-2003, 10:59 AM   #6
apstguy
LED King
apstguy's Avatar
TTT
Tyler
2016 Chevy Spark EV
Gone: 2008 VW R32
Old 07-26-2003, 11:33 AM   #7
Jonboy
Slots go on anything!
yes. repair or replace the vacuum line and the problem should go away. BTW, the MAP really does not have a lot of effect on the way your truck will drive, so it is not something to really worry about. The light is more of a nuisance on a carbed vehicle anyhow. The reason it is on is because the sensor is not getting a vacuum signal without the line attached. Make sure the plug is in tight, put vacuum to it, and it will be fine.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 07-26-2003, 02:17 PM   #8
apstguy
LED King
apstguy's Avatar
Thanks!
Tyler
2016 Chevy Spark EV
Gone: 2008 VW R32
Old 07-28-2003, 12:36 AM   #9
apstguy
LED King
apstguy's Avatar
That night it was dark and I was tired and hot. I looked at it today and found that the line was just un-plugged! Problem solved! I did however find out they don't make that hard plastic emissions vaccuum tubing anymore. Not the Chevy dealer, Kragen, or Autozone has it. Kragen used to 6 months ago. Maybe I get one of those special emissions exempt things because my hoses are all split? (I don't know HOW that would happen...)
Tyler
2016 Chevy Spark EV
Gone: 2008 VW R32
Old 07-28-2003, 01:41 AM   #10
TIMSPEED
TIMSPEED's Avatar
How do the subs sound??
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 07-28-2003, 01:48 PM   #11
apstguy
LED King
apstguy's Avatar
Subs are great! I have to fine tune the amp though, it can get a little boomy at times. I have the crossover set too high. I love it. Can't really hear them outside the cab which is a good thing because if you cruise around town with subs and let everyone know, they will be gone the next day!
Tyler
2016 Chevy Spark EV
Gone: 2008 VW R32
