"brand new second-hand"
anyone had this happen before? (yet)
Noticed today that when I use the turn signals, the drivers side blinks as normal but when I use the passenger side it goes really slow-it blinks but really slow. I changed the flasher unit in the fuse panel and checked both bulbs and they work, again just slow. any suggestions on what to do next?
Steve 69 3/4t custom camper tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c 67 Camaro 96 Impala ss-sold 04 hybrid Honda-saving gas for the blue truck!:b69: |
Re: anyone had this happen before? (yet)
check for a bad ground
![]() Join Date: Jul 2010
agree with the ground check, follow the wires inside your radiator support/inner fenders to see if one came undone, also make sure all your turn signal bulbs are working. Make sure turn signal wires are connected tightly (the factory rubber connectors)...hope you solve it.
Man of Mini-Talents
The side marker bases also need to be grounded, so be sure to check those in addition to the turn signal bases.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
