Old 05-28-2011, 03:14 PM   #1
aboz
aboz's Avatar
Steering column length
Anybody happen to know the length of the steering column on my '63 step side column shift? 30", 32" or 33"?...and, when ordering a replacement column, does it matter if my transmission has overdrive (granny gear) or not?
ABOZ
aboz is offline   Reply With Quote
Old 05-28-2011, 03:48 PM   #2
Clyde65
Clyde65's Avatar
Re: Steering column length
where are you ordering from? yes it will matter for the aftermarket ones since they sell the indicator too.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-28-2011, 03:52 PM   #3
Indian113
Indian113's Avatar
My column I bought from CPP came with 3 and 4 speed indicators for the auto trans also the shifter bracket is different for 3 and 4 they sent both of them too.
Indian113 is offline   Reply With Quote
Old 05-28-2011, 04:34 PM   #4
Indian113
Indian113's Avatar
Just in case you interested CPP is having a 3 day Memorial weekend sale, use code MD2011 for 10% off
Old 05-28-2011, 10:51 PM   #5
DCOOKE62
Indian, Can you tell me which column you ordered from CPP. Thanks.
DCOOKE62 is offline   Reply With Quote
Old 05-28-2011, 11:30 PM   #6
newagecustom
c10 Chop Artist
newagecustom's Avatar
If you use a universal fit column i believe you need a 33".
newagecustom is offline   Reply With Quote
Old 05-28-2011, 11:44 PM   #7
towersddg9
towersddg9's Avatar
I bought the ECSC-S 33 inch both 3 and 4 speed came with it, still in the box, they(CPP) also hooked me up with everything to the pwr steering gear, column looks great and was by far the best price vs all the others I looked at, this was about 3 or 4 months ago, looks like they made some changes to the catalog but give em a call 800-522-5004
towersddg9 is offline   Reply With Quote
Old 05-29-2011, 12:25 AM   #8
DCOOKE62
Im a big guy do yall think a 30" will work and give me some extra "room"?
Old 05-29-2011, 06:32 AM   #9
tazattitude
tazattitude's Avatar
I also went with the CPP universal 33". You have some play in which you can move it up or down.
TAZ
BUILDS
1966 GMC Suburban
1963 GMC Suburban Patina frame-on FOR Sale
1966 C10 Short Bed (2010-11)
Monthly Updates
2015 C10 Pics with my '72 Montego GT 429/521 build
1963 Pro Street C10 back halved. Frame off I did back in 1990
Pics / Video
tazattitude is offline   Reply With Quote
Old 05-29-2011, 06:41 AM   #10
Indian113
Indian113's Avatar
I bought the Economy 33in. Street Rod with auto shifter. I haven't put it in yet as I'm putting in a 700r4 first.
Old 05-29-2011, 07:47 AM   #11
johan 1
I bought a 33" colum ,also from cpp.
johan 1 is offline   Reply With Quote
Old 05-29-2011, 08:28 PM   #12
wildearp
wildearp's Avatar
It depends on how close you can get the column beauty rings to the dash. When I use a GM column, I cut the lower ring as short as possible to get them close to the dash. The trucks are very tolerant to several different lengths of columns, because the steering shaft can be cut to fit many lengths.
For instance, I put a '78 suburban tilt column in mine, which tends to run a bit long. Cutting the beauty ring gets it close to the dash and that is where you make some room.
wildearp is offline   Reply With Quote
Old 07-28-2011, 10:47 PM   #13
wildearp
wildearp's Avatar
Found the photos:
This is a 73-87 Suburban column. I cut the round steering shaft and ground it into a DD. It is a driver at this point, so things are not so clean.
