Old 07-26-2003, 01:06 PM   #1
brad20653
Engine swap help
A truck im thinking about getting had a 6cyl in it i want to put a v8 small or big block will everything line up ? Harness , electrical etc.
brad20653 is offline   Reply With Quote
Old 07-26-2003, 04:43 PM   #2
brad20653
1
Old 07-26-2003, 06:41 PM   #3
krue
Designated A-hole!
krue's Avatar
You'll need mounts for a small block, and the wiring harness can be modified (I did it back when I was a kid). It's not a hard swap and the guys on this board can give you a lot of tips to make it go easier.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 07-26-2003, 06:49 PM   #4
lukecp
Formerly yellow72custom
lukecp's Avatar
You can even use the stock 6-cylinder mounts, but the distributor cap will be close to the firewall....and a HEI distributor may not fit. It is a very easy swap, and whatever parts you need are easy to find and cheap to buy.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 07-26-2003, 10:52 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
In addition to yellow72custom's responce...that will only work if your inline is a 250. The 292 has one inline mount, and one small block mount if memory serves.
Old 07-27-2003, 01:56 AM   #6
jjk3
It's just a check engine lamp.
jjk3's Avatar
Noooo......keep the inline, or donate it to me. I went the opposite way. I went from a 327 to a 250. I swapped the 327 towers out for the 250s and that was it. I had like 4 or 5 wires to hook up after I swapped in the 250. It's really easy. The passenger side 292 mount is farther forward than the driver's side. The passenger side 292 mount is where the fuel pump on a 250 is. Hope this helps. Save the sixes. Donate them to me. It'll be much more fun when you smoke a V-8 with an I6.
BTW---Andy, when a woman wears a shirt like that you're supposed to guess SIZE. Just tell her you need to hold them to be absolutely certain what size they are.
Active Inliner---bigchevy66
68 SWB Stepside 250 L6/3 on the floor/ Hedman headers, HEI, MSD 6A box, K&N filter, Offy intake and Edelbrock 600cfm 4 barrel
Soon to have: WC T-5 five speed
66 SWB Stepside-undergoing restoration
jjk3 is offline   Reply With Quote
