Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 05-31-2011, 07:53 AM   #1
99-LS1-SS
99-LS1-SS's Avatar
Anyone use a parts washer at their house?
If so what is your opinion and which brand did you get?
99-LS1-SS is offline   Reply With Quote
Old 05-31-2011, 08:17 AM   #2
hgs_notes
GEARHEAD
hgs_notes's Avatar
Re: Anyone use a parts washer at their house?
harbor freight 20 gallon. It works fine. The main thing is the fluid you use in it. In my experience the "green" cleaners just don't work as well as the mineral spirits normally used. I got mineral spirits at a farm/fleet store for around $40 for a 5 gallon pail.
hgs_notes is offline   Reply With Quote
Old 06-01-2011, 07:51 PM   #3
Torrey72
Rollin in my K5 toaster
Torrey72's Avatar
X2
Harbor Freight has all kinds of low cost Chinese tools that work well. Not the hand tools, but all the shop goodies like the wash tanks, engine stands and hoists and stuff.
Torrey72 is offline   Reply With Quote
Old 06-01-2011, 11:50 PM   #4
rsavage
rsavage's Avatar
I have a 20 gallon parts washer I bought at Tractor Supply Company for $90 on sale. It is probably identical to the Harbor Freight one. It works well. The two five gallon pails of cleaner cost almost as much as the washer. For years prior, I used kerosene. It worked well but was smelly and flamable.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 06-02-2011, 06:31 AM   #5
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I too have a H.F. unit only my pump died shortly after switching to actual solvent. I first tried their water based cleaner, pffft, what a joke! Might as well fill it with Windex, would work alot better!
I just use mine the manual way without the pump. Not worth bothering with.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 06-02-2011, 10:43 AM   #6
cdowns
cdowns's Avatar
i had a great parts washer at my house.
then my nephew grew up and joined the army so no more parts washer
Old 06-02-2011, 12:13 PM   #7
Notch1988
Notch1988's Avatar
Notch1988 is offline   Reply With Quote
Old 06-03-2011, 08:46 AM   #8
tow guys
tow guys's Avatar
I have the HF 20 gal one also. I use purple power for most cleanups. For stubborn grease I use por15's marine clean. Neither seem to be having any ill effects on the pump after 5+ years.
Check out my 70 GMC tow truck project here.......http://67-72chevytrucks.com/vboard/s...d.php?t=440431
Member of the 1-Ton Club!
http://www.eastcoastcarandtruck.org
tow guys is offline   Reply With Quote
Old 06-03-2011, 03:17 PM   #9
buffle
buffle
buffle's Avatar
HF works well , just don`t expect the pump to last. If they sold replacement pumps, these would be excellent for home use.
buffle is offline   Reply With Quote
Old 06-03-2011, 03:38 PM   #10
JimmyFloyd
I have a Clarke one from Tractor Supply (Clarke is now out of business) Never actually used it since I never found a good cleaner to use with it, and it since got buried under stuff. Would like to hear recommendations on a good all-purpose cleaner though, as I will be digging it out in july when I reorganize the garage.
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3
JimmyFloyd is offline   Reply With Quote
Old 06-04-2011, 12:29 AM   #11
ETsC10
Hand Crafted C-10
ETsC10's Avatar
In my experience...
1. Generally, pumps cost as much as the whole unit.
2. If you can get concentrated bilge cleaner (used on industrial boats),
it works awesome!
3. A big tray with mineral spirits and a brush work fine. Don't smoke.
4. Don't use gasoline.
I do not have a parts cleaner at my house but have used
#2 & #3 at my hobby garage.
ET
ETsC10 is offline   Reply With Quote
Old 07-13-2011, 06:05 PM   #12
CrewCab59
CrewCab59's Avatar
I have a 20 gal from Northern tool ,been working for the last 3 years with almost every day . The only problem after I filled it up found a pin hole in the tank , good thing for the drain on the bottom.
1972 Custom Deluxe 20 4x4 burb
1971 GMC SWB CST 4x4
1972 GMC k20 4x4 (X- brush truck )
1971 Chevy CST Blazer 4x4
1971 Chevy C/10
1970 Cab Chassis C30 157"
1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica )
1988 Chevy V30 4x4 wrecker challenger 4812
CrewCab59 is offline   Reply With Quote
Old 07-13-2011, 08:49 PM   #13
Shane
Shane's Avatar
20 gallon Harbor Freight special ... full of kerosene. Cleans like the devil.
Shane is offline   Reply With Quote
Old 07-16-2011, 06:25 PM   #14
MadManAndrew
I don't know what size mine is, I think 5 gallon? Got it from harbor freight.
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061
MadManAndrew is offline   Reply With Quote
Old 08-04-2011, 04:16 PM   #15
fishingjred73
fishingjred73's Avatar
Originally Posted by ETsC10 View Post
In my experience...
it works awesome!
ET
A qt of this makes 96 gallons so I may splurge and try it. I only need 20 gallons so I'll just make it more concentrated. http://www.westmarine.com/webapp/wcs...classNum=11173
James
'68 Stepside (ground up in progress)
My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html
'81 SWB "Pap paw" (Driver)
The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html
Member of
www.louisianaclassictruckclub.com
https://www.facebook.com/groups/296290610747732/
fishingjred73 is offline   Reply With Quote
Old 08-11-2011, 05:45 PM   #16
fishingjred73
OK I wouldn't recommend the bilge cleaner I posted the link to above. Not real impressed with the results, so I'll be replacing it as soon as I find some solvent.
James
Member of
Old 08-11-2011, 06:25 PM   #17
BarryB
BarryB's Avatar
Well mine isn't from Harbor freight. I bought mine when Homier truck tool sale was in town. BUT it is the same one Harbor freight sells just a different color. Mine has been doing me fine. I went to Lowes and bought couple 5 gallon pales of mineral spirits. Does great. My pump as been fine so far.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
