Old 05-31-2011, 06:54 PM   #1
brad_man_72
the boat guy
brad_man_72's Avatar
Angry pulling my hair out. Front bumpstops!
67 crossmember 76 everything else front end. I'm spending more money on bumpstops than gas these things won't stay in. I've evn ruined 2 good tires. Only the drivers side falls out 5th one in 6 months I'm using energy suspension poly bumpstops I've tried glueing them in I've tried screwing them in. I'm about to run some steel through one and weld it in. It does touch the bumpstops at ride height. I love the way it rides and handles with this setup I just cant make it last. Do I need to bite the bullet and get nw springs shocks and some drop spindles.......
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 05-31-2011, 09:04 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: pulling my hair out. Front bumpstops!
I see in your sig you have a 4/6 drop. How was that acquired up front? You will probably need to remove the B/S mount and build a new one.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-31-2011, 09:08 PM   #3
brad_man_72
the boat guy
cut springs in front. Drop springs out back.
factory bumpstops didn't fall out, they rotted and split.
Old 05-31-2011, 11:12 PM   #4
SCOTI
SCOTI's Avatar
Get more factory bumpstops. I picked up new ones @ my local dealership around 09.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-01-2011, 07:12 AM   #5
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Is your truck riding on the bump stops all the time?
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 06-01-2011, 08:18 AM   #6
m6z
m6z's Avatar
Damn, 4" is a lot to cut out of a spring.
Doug
Looking for a 67-72 short bed driver.....
m6z is offline   Reply With Quote
Old 06-01-2011, 08:47 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
That's why I asked. That's 2x to much drop from a front spring. Your pounding the snot of of the stops.
Articles-
"Refining Sierra"
Old 06-01-2011, 09:57 AM   #8
Tony@AirRideTech
Junior Member
yup... need to be dropped like that with conjunction of spindle and spring. Dont need to ride on the bumpstop either. when you do that you are not getting enough suspension movement and the stops are taking the load.
Tony@AirRideTech is offline   Reply With Quote
Old 06-01-2011, 10:36 AM   #9
19seventeeCustom
HOLY smokes batman!!
4" cut off the front spring???
you need to buy a 2" drop spring along with a 2" spindle to remedy this.
Good luck!!
19seventeeCustom is offline   Reply With Quote
Old 06-01-2011, 10:53 AM   #10
SCOTI
SCOTI's Avatar
Each of my previous rides had 1-coil cut from original springs (2-3" drop). On the 68, I had about .500-.750" clearance between the bumpstop & x-member. On the 74, it was .500" max.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-01-2011, 01:47 PM   #11
brad_man_72
the boat guy
riding on them not so much but def no clearance.
even sitting on the bumpstops the trcck rides pretty nice. Way better than the wet sponge it was before.
drill holes in the bumpstop to make it more pliable?
Old 06-01-2011, 01:53 PM   #12
brad_man_72
the boat guy
no luck w local dealer for original rubber bumpstops.
Old 06-01-2011, 04:48 PM   #13
Brandonc20
How much can you cut out of a 2 inch drop coil from early classic?
Brandonc20 is offline   Reply With Quote
Old 06-01-2011, 05:57 PM   #14
SCOTI
SCOTI's Avatar
That's a vague question. If it's a 2" drop, & you cut 1-coil, your @ approx 4-5" of drop which is too much 'spring only' drop. You would need to cut less but how much is dependant on age of springs & vehicle weight (there's no 1 right answer).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-01-2011, 09:25 PM   #15
Brandonc20
These coils are brand new they have been on my truck for about a month. Weight wise....idk....its a c20...is there a safe cut? I don't want to have the problem this guy is having but I do want to drop it because I'm putting two inch drop blocks in the rear with my four inch drop coils.
Old 06-01-2011, 09:32 PM   #16
SCOTI
SCOTI's Avatar
I do not recommend more than 2" of drop using coils. You should combine spindles w/drop coils. If you go more than 2" of drop (cutting a 2" drop coil is more than 2" of drop), you will most likely encounter the exact problem the original poster is having.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-01-2011, 10:38 PM   #17
N2TRUX
Happy to be here
N2TRUX's Avatar
.... (there's no 1 right answer).
I disagree. You prove my point with your answer below.
Articles-
"Refining Sierra"
Old 06-01-2011, 10:42 PM   #18
SCOTI
SCOTI's Avatar
My comment.....
.... there's no 1 right answer
....was for cutting springs only .
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-01-2011, 11:34 PM   #19
Brandonc20
Don't I need disk brake if I want to use drop spindles
Old 06-02-2011, 08:37 AM   #20
N2TRUX
Happy to be here
N2TRUX's Avatar
Yes, you will need to convert to disc brakes to run dropped spindles.
Articles-
"Refining Sierra"
Old 06-02-2011, 09:42 AM   #21
Shane
Shane's Avatar
... oh the joys of doing something half-a%%
Shane is offline   Reply With Quote
Old 06-02-2011, 01:34 PM   #22
brad_man_72
the boat guy
half an butt is all I have left. Building a house, keeping the boat running and fed, plus a handful of other hobbies and a woman thats out of work doesn't leave me in a real good position to be buying a new suspension for my truck.....that I have to drive to work.
Old 06-02-2011, 05:29 PM   #23
Shane
Shane's Avatar
all I am saying is if you keep buying bump stops then eventually you will have spent what it would have cost to do it right the first time.
Buy once. Cry once. Go cheap. Forever weep.
Old 06-02-2011, 06:37 PM   #24
tubbedII
needs more $$$
tubbedII's Avatar
I take it that you find out the bump stop is gone when you start feeling the metal-to-metal thud on the drivers side? Is cutting the bump stop mount all the way off and adding one directly on the control arm out of the question?
I don't know if this will allow too much travel in the suspension though in your situation...
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 06-02-2011, 07:45 PM   #25
crazy longhorn
Fabricate till you "puke"
Thats the route I took....ct the bumpstops off the lower arm, & used traction bar snubbers for the new bumpstop. I only cut 1 ring on the coil tho... crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
