Old 06-01-2011, 07:33 AM   #1
OJ1988
Just a car guy
OJ1988's Avatar
3"/5" drop, front higher
Just got my rear springs in and now my front is sitting 1/4" higher.
Used cpp springs.
I am adding the adj rear track bar which will lower the rear another 1/4". Aldo swaping to a blazer tank which will put more weight on the rear.
Someone said , "let the springs settle"
the fronts have been in the truck for almost 6 months. If anything "settles" I only see the rear going lower.
So my options are?
1. Cut front springs
2. Swap to 2" springs and drop spindles? ( costly)
or?
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 06-01-2011, 08:30 AM   #2
68Stepbed
68Stepbed's Avatar
Re: 3"/5" drop, front higher
I've heard this alot from CPP products. I would be afriad cutting the front springs any more would cause problems. I would do a spindle/1" spring drop in front. Have you already converted to disc brakes?
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 06-01-2011, 08:59 AM   #3
70cst
70cst's Avatar
Used cpp springs.
So my options are?
or?
I would go with #2 or at least the 2" drop springs.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 06-01-2011, 09:40 AM   #4
cdowns
cdowns's Avatar
get larger rear tires
Old 06-01-2011, 09:59 AM   #5
70cst
70cst's Avatar
Good possibility
Old 06-01-2011, 01:29 PM   #6
JORGIE95961
Originally Posted by oj1988 View Post
just got my rear springs in and now my front is sitting 1/4" higher.
Used cpp springs.
the fronts have been in the truck for almost 6 months. If anything "settles" i only see the rear going lower.
So my options are?
or?
posted via mobile device
air shocks will lift that back end up
JORGIE95961 is offline   Reply With Quote
Old 06-01-2011, 03:18 PM   #7
OJ1988
Just a car guy
OJ1988's Avatar
Yes I have converted to disc,
as for tires I have new tires all around and want the same size for rotation, spare and speedo purposes.
Before I had cut stock springs in the front and it sat lower and rode ok,
I'm thinking 1/2 coil off the front would get me there.
1973 Vega Drag Car
1970 C20 tow rig
Old 06-01-2011, 03:35 PM   #8
JORGIE95961
1/2 COIL MAIGHT MAKE THE SPRING NOT SIT RIGHT.. if your stuck on cutting do a full coil
Old 06-01-2011, 03:47 PM   #9
leddzepp
Moderator
leddzepp's Avatar
cutting half a coil will yield approx 1" drop, a full coil 2" drop.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 06-14-2011, 07:19 AM   #10
OJ1988
Just a car guy
OJ1988's Avatar
Here it is with 3" fronts and 5" rears.
1973 Vega Drag Car
1970 C20 tow rig
Old 06-14-2011, 07:19 AM   #11
OJ1988
Just a car guy
OJ1988's Avatar
1973 Vega Drag Car
1970 C20 tow rig
Old 06-14-2011, 09:09 AM   #12
68Stepbed
68Stepbed's Avatar
I suggest a spindle/spring drop.
Matt
Old 06-14-2011, 09:32 AM   #13
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
cut a 1/2 coil, it'll be fine.
Old 06-14-2011, 12:41 PM   #14
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
I wouldn't cut any more spring out of the front. You notice nobody sells 4" front lowering springs. That is because the spring will rattle around in the pocket. 3" is max and I advise my customers not to even do 3" because I feel the spring is too short. I would go to a drop spindle and 1" front lowering springs. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 06-14-2011, 12:50 PM   #15
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Stance looks good to me!
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 06-14-2011, 01:06 PM   #16
OJ1988
Just a car guy
OJ1988's Avatar
None has been cut from the front in those pics.
I have cut a half coil off and will get pics posted.
The rear is coming down another 3/8" due to the cpp long track bar installation.
With the old cut stock springs the front sat about 1" lower than it does now. The ride was acceptable to me.
I'll post pics in the next day or so with the 1/2" coil cut front.
1973 Vega Drag Car
1970 C20 tow rig
Old 06-14-2011, 01:07 PM   #17
OJ1988
Just a car guy
OJ1988's Avatar
Drop spindle and a 1" spring would put me where I am now. I need a drop spindle and a 2" spring, or bags I guess
1973 Vega Drag Car
1970 C20 tow rig
Old 06-14-2011, 08:42 PM   #18
C/10 King
C/10 King's Avatar
Gary
X2, This stance looks great!
C/10 Rene
1966 Short Fleet "The Hag"
1967 CST Short Fleet "Dark Poly"
1971 Short Fleet
1970 Jimmy Custom 2 WD "Golden Ticket"
1972 Blazer 2 WD "Retro Blaze"
C/10 King is offline   Reply With Quote
Old 06-14-2011, 08:59 PM   #19
Boog
laying low
Boog's Avatar
Where are you measuring your drop? Center of fenderwells? You know they measure different from the factory right? Did you put on lowered shocks too? Everybody has their own tastes ya know but I'd raise the rear up an inch and drive the wheels off of it. It'll take the bumps and potholes better if you don't go any lower in the front. JMO
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 06-14-2011, 09:37 PM   #20
OJ1988
Just a car guy
OJ1988's Avatar
I want a little more rake. It was lower in the front before will stock shocks and cut springs. I drove it everyday and if wasn't bad to me, the rear was worse, it had heated coils and only one or two worked!
Yes I am measuring to the wheelwell center. I am comparing to the measurements before. It sits lower in the rear then before but a little higher in the front, then before, cut one half coil on one, still got to do the otherside.
Yes I added drop shocks. Toxic shocks front and rear.
Added shorter poly bumpstops as well.
Front also got shock brackets, '78 a arms, spindles, steering links, all new, new balljoints,
poly bushings, 1.25" sway bar.
Rear I am adding the cpp long panhard bar, shock relocating mounts.
I am use to driving camaros with stiff springs.
1973 Vega Drag Car
1970 C20 tow rig
Old 06-14-2011, 09:50 PM   #21
Hubscrub
Cruzin
Hubscrub's Avatar
you could always add a bigger/heavier motor/ i think it looks good now but do it till it pleases you.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 06-16-2011, 05:25 PM   #22
OJ1988
Just a car guy
OJ1988's Avatar
Here it is with a 1/2 coil off the front.
1973 Vega Drag Car
1970 C20 tow rig
Old 06-18-2011, 03:13 PM   #23
OJ1988
Just a car guy
OJ1988's Avatar
What do you think?
1973 Vega Drag Car
1970 C20 tow rig
Old 06-18-2011, 03:17 PM   #24
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
I like it!
So how does it ride now?
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 06-18-2011, 03:40 PM   #25
OJ1988
Just a car guy
OJ1988's Avatar
Not quite ready to road test bur will let you know as soon as I do!
1973 Vega Drag Car
1970 C20 tow rig
