Old 06-02-2011, 12:28 AM   #1
willstruck
tv cable, carb spacer
So, my truck was kicking down a gear going up hill kinda early in my opinion. Put in a 2" carb spacer, now it kicks down with hardly any pressure on the accelerator. So, I looked up the procedure for adjusting the tv cable, but couldn't find what tab you pull out before you open the throttle. Nothing I found online made sense with what I had going on. This morning, I was going up a hill, it kept kicking down a gear, and shifting back up. Figured if I floored it, at least it would stay in the lower gear and make it up the hill. Just kept dropping down, and shifting back up. Any tips on adjusting this?
'85 k10 long bed, 6" lift. 35" tires. 350, Edelbrock intake/carb, headers, dual exhaust. Automatic.
willstruck is offline   Reply With Quote
Old 06-02-2011, 12:39 AM   #2
Togart
Togart's Avatar
Re: tv cable, carb spacer
Is it a TH350 or 700-R4? If it is a 350, there is a clip that pops up right behind the bracket if you press from underneath. If it is a 700-R4, there is a D-shaped pad on the bottom that you press and hold while moving the throttle to WOT.
Togart
'66 GMC 1500
'77 C-10 Scottsdale Big 10
Togart is offline   Reply With Quote
Old 06-02-2011, 12:41 AM   #3
willstruck
Thanks. Not sure which it is. Truck came with 4 speed according to build tag. I'll check if it has the clip or the pad, thanks.
Old 06-02-2011, 12:41 AM   #4
lindstromjd
Gentleman Jim owner x2
lindstromjd's Avatar
It's a "button" of sorts on the 700r4 that looks like a capital D. Push it in and hold it. Push the nose of the TV cable all the way towards the firewall. Let go of the D button. Get inside your truck, and put the throttle to the floor. You should hear some clicks, and that will set it.
All of that with the engine off, of course. Have to say it... because you know some people will try it the other way around.
Looks like we all jumped on that one pretty quick...
1975 GMC Gentleman Jim #1
-357 / 700r4
1975 GMC Gentleman Jim #2
-350 / TH350
lindstromjd is offline   Reply With Quote
Old 06-02-2011, 12:49 AM   #5
willstruck
I can't find a clip or a D shaped button to push. Since the tranny isn't original, it had a manual, what other options could the cable be?
Old 06-02-2011, 11:07 AM   #6
lindstromjd
Really need to know if it's a TH350 or a 700r4. Or at least some pix of what you're working with?
-357 / 700r4
-350 / TH350
Old 06-02-2011, 03:10 PM   #7
willstruck
How do you tell which tranny it is?
Old 06-02-2011, 04:08 PM   #8
lindstromjd
Easy way is look at the pan. Does it look like a big square? Or does it look like a square with a corner cut off it at an angle?
-357 / 700r4
-350 / TH350
Old 06-02-2011, 05:18 PM   #9
willstruck
Corner cut off. I'm zt work or I would post pic of carb linkage
Old 06-02-2011, 05:30 PM   #10
lindstromjd
That's a TH350. You have a kick-down cable. It's probably adjusted to kickdown way too early. You can take it completely off and see what happens. The TH350 won't destroy itself with the kickdown off like the 700r4 will with the tv cable off.
-357 / 700r4
-350 / TH350
Old 06-02-2011, 06:35 PM   #11
makman1297
makman1297's Avatar
I put a 1" spacer on mine and used the factory kickdown bracket. On mine i had to take it off the bracket and the square cut end of the cable, where it goes into the bracket was threaded. So i would pull it out and adjust the length by threading the cabel. I set it up so with the carb at full throttle you could pull the TV slider about 1/8 to 1/4 farther. I have never had any problems with mine and i think the kick down is just right.
makman1297 is offline   Reply With Quote
Old 06-03-2011, 07:04 AM   #12
willstruck
I disconnected it. It's weird, my gas pedal is so easy to push now. I might try to fix it this weekend.
Old 06-03-2011, 07:36 AM   #13
cr34t3d_by_d4rkd3n
ever owned a bicycle? ever had to adjust the brake cable? same concept im sure. never adjusted one before, just follow the cable down to the transmission and take a look see.... but dont drive that truck without the trans cable connected. it will not supply adequate hydraulic pressure and can torch a transmission... adjust the linkage before you either blow it up from popping around the gears at high speeds or not connecting the cable and smoking a tranny.....
cr34t3d_by_d4rkd3n is offline   Reply With Quote
Old 06-03-2011, 10:30 AM   #14
lindstromjd
He's got a TH350... not a 700r4. That thing will survive forever without the kickdown cable attached. Nothing to be concerned about. I had one behind my 6.2 diesel before I swapped it out for the 700r4, and I drove it for over 2000 miles without the kickdown attached.
Anyway, if you do get a chance to snap a picture of what your cable looks like, someone should be able to figure out how to adjust it.
-357 / 700r4
-350 / TH350
Old 06-04-2011, 01:21 AM   #15
cr34t3d_by_d4rkd3n
th350 adjust's pump pressure via the kick down cable's pulled position, a disconnected kick down cable will show an"at idle" condition constantly.
do ur hw before u give people the ol "eahhhhh u dont need this! extra parts!!"
Old 06-04-2011, 05:25 AM   #16
BamaDave
I am interested in this also. I just bought a spacer to put under my Holley. It is only a little over 1/2". Will I have to adjust the kick?
BamaDave is offline   Reply With Quote
Old 06-04-2011, 10:36 AM   #17
Togart
Togart's Avatar
Thats how a 700-R4 functions. The TH350 uses a vacuum modulator instead and the cable is just for kickdown.
Togart
'66 GMC 1500
Old 06-04-2011, 11:34 AM   #18
fanmanj
fanmanj's Avatar
Jay Bernard, Thibodaux, LA
1986 SWB Sierra Classic
Stock roller 350/700R4
2008 Buick Enclave CXL
3.6 VVT, 6spd auto.
PAINFULLY stock... (wife's ride)
fanmanj is offline   Reply With Quote
Old 06-04-2011, 02:53 PM   #19
willstruck
here's the cable
Old 06-05-2011, 12:37 AM   #20
Togart
Togart's Avatar
Yours looks slightly different than mine...I think you have a newer cable. I attached pics of how my aduster clip looks, anyway, in case something jumps out at you. The first is of it closed, the second of it open. Again, I just have to push from underneath and it pops up enough for me to grab it and lift it.
Dunno how much they changed it...maybe someone else here has a newer cable like yours.
Togart
'66 GMC 1500
Old 06-05-2011, 12:40 PM   #21
lindstromjd
Originally Posted by fanmanj View Post
Thanks for the backup guys. Do your own homework when it comes to transmissions. That's why I put the explanation of WHY it isn't necessary when I said that you can drive without it connected. You think a TH350 would survive for over 2000 miles without the kickdown attached if it depended on it like the 700r4 does with the TV cable? Prove to me why I was able to do that then. All the kickdown does on a TH350 is open up extra valves when you "floor the throttle" to create more pressure to get the transmission to downshift. At normal throttle position, it isn't doing anything for the transmission. It is not necessary AT ALL to everyday driving operations. I know the differences between the two transmissions. End rant.
-357 / 700r4
-350 / TH350
Old 06-05-2011, 12:49 PM   #22
rayfinseats
"TH350 won't destroy itself with the kickdown off like the 700r4 will with the tv cable off."
If it is a 700r4 and the cable isn't adjusted right you'll be buying a new transmission.
rayfinseats is offline   Reply With Quote
Old 06-05-2011, 01:43 PM   #23
willstruck
I think a previous owner converted it to automatic, so the kickdown cable wouldn't have been there before. Who knows what it came off of...
