Old 07-27-2003, 02:08 PM   #1
BrianStep72
BrianStep72's Avatar
WTB: AIRBAG for 72 COIL SPRINGS
I would like to buy a heavy duty rear airbag kit for my 72 with coil springs. Does anybody have one for sale? Or can anyone recommend one which FITS PERFECTLY with minimal mods and fabs. (maybe a bolt in).
Is it OK to bag just the rear, or should I do the whole truck at once? Thoughts?
Part # and manifacture appreciated..
Thanks!
Brian LaRose
Atlanta, GA
1972 C10 Stepside.
1941 Chevy Coupe Streetrod
1964 Chevy Nova SS
1964 Chevy C10 Stepside Pickup
1972 Chevy C10 Stepside Pickup
1987 Chevy IROC Z28 Camaro 1LE+TPI - racecar
2004 Chevy Tahoe
2013 Chevy Silverado Tow Rig
http://www.bowtieracing.org
BrianStep72 is offline   Reply With Quote
Old 07-27-2003, 03:05 PM   #2
72longbed
72longbed's Avatar
BrianStep72,
ECE has the kit that you might want. It's listed as a heavy duty rear air bag kit with all the necessary parts included. I think they actually had the bags custom made for them to use on this kit. Check it out, it comes with shocks, shock relocator kit, Super TracBar kit, new brackets, U bolts, all hardware. The compressor kit is optional. BTW, better save your pennies, it ain't cheap!!!
72longbed is offline   Reply With Quote
Old 07-27-2003, 09:47 PM   #3
BrianStep72
Question ANYBODY HAVE ONE OF THESE?
Guys, I was searching around the net and found something that is LIKE what I was looking for. It's NOT the full blown air bag system from ECE.
Does anybody use something like this and what are your thoughts?
BrianStep72
1964 Chevy Nova SS
2004 Chevy Tahoe
Old 07-28-2003, 03:09 PM   #4
cped
What are you trying to accomplish? That would be a better way to approach it. The kit you posted is designed to fit inside your coil springs and only be used as a load leveling or load assit.
If you are looking for ride height adjustability, ride quality, ease of installation then the ECE kit is the way to go. I have had mine installed for over 2 years now and it works beautifully. Ride quality is excellent. I have certainly put it through its paces with a yard of bark, 3/4 ton of gravel, 100+ yard stack stones etc.
Chad
cped is offline   Reply With Quote
Old 07-28-2003, 03:33 PM   #5
72longbed
72longbed's Avatar
cped,
I've been thinking about buying that ECE kit for my truck but it's so darn expensive! Do you have the stock front suspension or have you lowered it? At what height do you keep the rear, and how many pounds does it take to keep it there? Is the ride quality better than a stock coil setup at the same height? Not just bumps but handling, cornering etc..? Did you get the compressor kit too or are you using schrader valves on each side?
Thanks for the info.
Old 07-28-2003, 06:16 PM   #6
BrianStep72
OK. I agree, let's start with the requirements.
1) I want setup a towing package on my truck. I will be towing a 3000 lb race car and trailer, so I would like to increase the leveling and capability of my shortbed. I will not be modifying the ride hight or slamming the truck to the ground.
2) I found out that I should put bags ALL THE WAY AROUND to be sure it will handle well.
i will be putting NEW heavy duty shocks all the way around at the same time I bag the coils. So i guess that's my plan. Do you think it will work?
Brian
1964 Chevy Nova SS
2004 Chevy Tahoe
