305 is out 350 is Almost all the way in! (305 autopsy photo's inside!)
yesterday, a buddy and I yanked the 305 out, and got the new roller 350 in place. The hard stuff is done, all thats left now are the driven accessories, intake, distributor, one exhaust manifold, and the valve covers. I really hate to put those strangled 305 "log" manifolds back on, but I'm building on a budget! the 350 looked Very clean inside.. one challenge tho.. the hole was there for a mechanical fuel pump, but there's no eccentric on the cam..
![]() We did tear into the 305 too.. Needed the oil pan for the 350, and popped the driver's side head off just for curiousity.. oil pan was full of sludge.. and 4 pieces of piston skirt!! and pulling the head revealed #7 piston is missing 1/3 of it's top ring land! and #7 had good compression! not to meantion the cylinders have a huge ridge at the top of the bore.. this thing was GONE pic of the new 350 ![]()
Jay Bernard, Thibodaux, LA 1986 SWB Sierra Classic Stock roller 350/700R4 2008 Buick Enclave CXL 3.6 VVT, 6spd auto. PAINFULLY stock... (wife's ride) |
Re: 305 is out 350 is Almost all the way in! (305 autopsy photo's inside!)
inside the 350 valve cover
305 getting pulled like a bad tooth
pieces of piston skirt that were in the pan of the 305
#7 on the 305... notice the broken ring land? where did it go?
a quick picture of the heat crossover port on the head... pretty disgusting..
Wow......
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. |
Check Bore diameter - stock 305 should be 3.735 and by the looks of it those pistons look like low grade replacement die cast aluminum (they look like SpeedPro 454NP). If the bore measures 3.765 (+0.030) someone been inside that little poor 305 before and did a half job - replacing OE pistons with non eutectic grade pistons. A truck engine should be built with higher quality pistons capable of withstanding long duration power output periods. A dish piston simply does not have crown material to dissipate heat!
Question - is that Harbor Freight cherry picker you are using to pull that 305 out. Did you have enough lift to clear radiator support?? //RF
"The Beast" 1975 Chevrolet C20 longbed 350/700R4! with 3inch body lift Dual Flowmasters Super 40's! TBI retrofit completed (2007-07-29) ![]() New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17) |
Well, I really don think the engine has ever been apart... No stamping numbers on the rods, and the head gaskets were thin steel, not composite replacements... I could be wrong tho... The picker is equivalent to a harbor freight one... I bought it at a "tool tent sale" about 8 years ago.. If you rig it up right, the engine clears the rad. Support fine.
#10 | |
//RF
Gentleman Jim owner x2
![]() Join Date: Oct 2010
1975 GMC Gentleman Jim #1 -357 / 700r4 1975 GMC Gentleman Jim #2 -350 / TH350 |
