#101 |
Re: I think I've decided on a build "theme"
It's kinda ironic how no matter how much money you spend on the nicest parts, soon the time to work on it becomes the hardest thing to save; my Blazer's been painted for 2 weeks and I haven't touched it yet!
1972 factory 2 Wheel Drive Blazer-Sold 1972 K10 4X4-Sold 1971 Chevrolet Cheyenne/10-Sold 1970 Chevrolet C/10-Sold 1968 GMC 4X4-Project 1968 Chevrolet C/10 Pro Street 1970 GMC 3/4 Ton-Parts 1997 2WD 2DR Yukon-Sweet http://67-72chevytrucks.com/vboard/s...d.php?t=335664 |
#102 |
It's been a while since I've updated this thread. We've had such a hot summer I didn't feel much like working on the Blazer.
I finally made some time this weekend. I bought some drop spindles and heavy duty springs since I'm putting a big block in it. I've never changed ball joints or spindles. I was nervous about doing the swap so it was easy to make excuses to not do it. This weekend I finally manned up and went for it. The driver's side took about 8 hours and 4 trips to the parts store and the passengers side took about 2 hours. I would have had it done sooner but the threads on the bottom ball joint were galled up some so I had to clean them up and that took about 30 minutes. I cut the heavy duty springs because I don't think the 2" spindle drop would be nearly enough. I cut 1 3/4 rounds out of the springs. Hopefully, the truck won't drag the ground once the engine is in it. If it does, I guess I'll get another set of springs and cut them less. I'm shocked at how little clearance there is between the steering arm and the rim. It was so close that it knocked the inside weight off of the rim. I guess I'll have to grind it some and maybe use a spacer just to give myself a little clearance. I changed the tie rods too. To type this out it doesn't seem like I didn't much but my back would beg to differ. My next hurdle will be the brake lines. I'm completely replacing the brakes since the whole system was in bad shape. After the brakes, I hope to swap the 3 on the tree column for the Automatic column. Here are the pictures. I know some people are going to give me crap for not painting the A-arms but this isn't a show truck. I am much more concerned about it being safe and reliable. The fancy stuff will come later after I get it back on the road. ![]() ![]() ![]() Last edited by 99-LS1-SS; 10-02-2011 at 09:12 PM. |
#103 |
Cool! nice to see your back on it
Cam 1972 Chevy C/10 "Custom Cruiser Project" Build Thread 1961 Olds Super 88 (Daily) 1966 Chevy Corvair 500, "Marigold" SOLD 2005 Subaru Outback Wagon DEAD 2008 Pontiac G8, New Winter/Daily |
#104 |
GEARHEAD
There are spring suppliers out there that will build he coils specific to the ride hieght you want based on the engine size, etc.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
#105 |
I might go that route if the springs aren't right.
#106 |
I know I'll be met with some disapproval but, I finally found someone who I think (and hope) will do a good job with the paint and body work. To pull the body off of the frame and get the frame and everything else looking good will be more than my time and current tool set will allow. Plus, I want this thing to be done right and look good the first go around. They are coming to pick it up Monday afternoon. I've done a lot of work to it so I don't feel like I'm completely *****ing out on this build (although, I do admit I feel like I'm *****ing out some). I still plan on putting the engine and transmission in myself. Basically, I'm doing everything but the body work and paint. Those are things better left to people that have the experience to do it correctly...the first time.
On a semi-related note, I'll be able to park the Tahoe back in the garage and I won't have to get into a freezing ass cold car in the mornings. |
#107 |
![]() Join Date: Aug 2010
Awesome truck, I am getting ready to start a '72 2wd Blazer build and I am down near Charlotte. Good to see another NC blazer!
Jeff 1972 Blazer CST 2wd- My son Sam's Project "S" Project "S" 1970 Suburban - SOLD "One Bad Burb" Photobucket Album 1986 C30 Crewcab - 63K original miles, original paint Members I have met: mikey531, gcburdic, bashed, burbman69, TonyPieras, Blazester, GCncsuHD, custombuilt67-72, tsnow678, highrpm, PanelDeland, tanman722001, 47thriftmaster, babyblueoval, 68stepbed, JesseWebb, Andy4639, xs-style, TobyArnot, BigOrange, frednoah, brn_agn, k5hart, Graham57a, bhelton, AJohn6, SilverC10, 69CST, '71 Flame, RaceAGMC, Liz, Josh, MattPSU, 68corvair, Chevy350V8, mdeal, ccrorymc, mrhurt73, dmxxpert, Custom68, 84GMC, BionicABs1, BigBlockBurris, Ebfabman, ATP... |
#108 | |
#109 |
#110 |
She's gone to get prettied up. It was pretty comical getting it down the driveway since his trailer was too low to get up the driveway without dragging. It doesn't have steering or brakes. I was modulating the emergency brake while he was manually steering the tires. It took about 10 minutes to go down a 40' driveway.
I can't wait to see some progress on the body and frame. The Tahoe is in the garage! |
#111 |
I finally have a minor update. It has been at the body shop for a couple of month. They've been busy getting other cars out before they could start on my. They've completely stripped and sand blasted the body. Once they get all of the patch panels in and get everything braced up they'll take it off of the frame and sand blast the frame. Here's a couple of pictures of the body after being sand blasted.
It's not much yet but it's progress and that makes me happy. ![]() ![]() ![]() |
#112 |
Any little glimmer is STILL light at the end of the tunnel!
#113 |
Cool project, don'y worry about farming out some of the work. Sometimes life gets in the way, and the only way get things done is to share the work
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
#114 |
I got some more update pictures!
![]() Here's the cowl being repaired. ![]() Here's the cowl...gone! Note the fancy floor pan. ![]() Them cleaning and straightening the cowl. ![]() Cowl back on and getting the doors lined up. I found out that GM still sells the hinges for this Blazer. ![]() More floor pan shots. ![]() All buttoned up. ![]() Getting ready to start on the driver's side now. Look at all the black spots on the door post. Those are holes. ![]() |
#116 |
I don't know the PN but I'll try to find it. You might be able to call a local dealer and see if they offer them. If not, here's the number Parts: 800-779-2433. It's called Modern Chevrolet.
#117 |
Good to see you've got a shop working on it that aint ascared to WORK on it!
#118 |
#119 |
Two minor update photos.
Passenger's side fender is on and fitted. ![]() Picture of the passenger's side rocker finally done. ![]() |
#120 |
67cheby
![]() Join Date: Sep 2008
nice work
#121 |
very nice
#122 |
Great Blazer! Looks like a good shop, who is it? Good work and a cute helper! Don't wanna be you in 10 years or so!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
#123 |
hello there nice truck i have a 3 on the tree also but that part is in peices do u have any pics at all where it bolts up to and where it goes to on the tranny thanks if u cna send me a few pics or a link to some pics ..thx again
#124 |
I think I have some pics of the steering column. Which area are you looking for?
#125 |
Got a few more update pictures. Most of the fabrication is done. Soon it will go to the body shop to get smoothed up and painted. Once, the body work is done the tub will be pulled off and the frame cleaned up and painted.
Here's the tub braced up. ![]() Driver's side door and fender on and fitted. ![]() Radiator support and front lined up. ![]() Patch on driver's side front quarter. ![]() |
