1961 crewcab
auto trans install?
putting a th350 in one of my trucks, does the center crossmember (under the flywheel) have to be removed, or will the trans fit by it?
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
![]() Join Date: Sep 2006
Re: auto trans install?
It will be easier to get the tranny in and out if you remove it. You also might have fitment problems. Just grind down the rivits and punch them out.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Last edited by Chevy Fleetside; 06-03-2011 at 08:03 PM. |
1961 crewcab
yeah.. thought so
![]() ![]() hey- has anyone found a driveshaft that is a bolt in for a longbox auto install?
60-66 Nut
I would definitely remove the bellhousing crossmember.
The length of the driveshaft will vary with the length of the tailshaft on the trans. I believe there are 3 length for the TH350. If it were me, on a long bed, I would stick with a 2 piece.
I agree with the Captain. The TH350 will fit with the original crossmember in there, you'll be a lot happier with it removed. It is a pain to take out, though.
1961 crewcab
hey sft I see you look to have a th350 what did you do for the drive shaft?
my th350 will be out of a 79 transam, not sure which of the 3 lengths that one is..
Double 6's
Mine had the 3 speed(LWB), I put a TH350, and the drive shaft fit....Now that I think about it, I guess that doesnt help any...sorry
Street Glidin! 1966 LWB Custom Cab (sold) 1982 Short Fleet (under the knife) 1998 S10 2wd Fleet 2007 Chevy Silverado Crew 2007 Harley Davidson Street Glide |
Hi Jon,
When I had the turbo 350, I just had the driveshaft cut down to fit. I wish I had an easier, cheaper solution. |
If you know someone with good welding skills and a mig welder you can shorten the shaft yourself. Balance it when finished, cost is about 40 dollars but worth every peny.
1961 crewcab
no that does make sense, the lwb 3 speed shaft is shorter than the 4...
