Old 06-04-2011, 08:31 PM   #1
CVA59
Starter Problem
Ok guys, I dropped a 78 model 350 in my 64. I kept the original 6 cylinder's 3 speed tranny with the original bell housing. I tried to install the 78 model starter and it won't mount up. Looking at the picture of an original starter for a 64 chevy w/283 & 3 speed. It looks like the top flange bolt hole will hit the block. I have not bought it yet but looking at everything i don't see how it will work. Any ideas what i have to do in this situation???? I did read in another thread on here about this somewhat. However, Something under there just doesn't look right to me. I guess i just need a good nights sleep and look it over again tomorrow, LOL.
Zack
www.23t.weebly.com
_________________________________
CVA59 is offline   Reply With Quote
Old 06-04-2011, 09:34 PM   #2
andyh1956
Re: Starter Problem
swap out the nose with the old starter & crank 'er up. don't forget to install the starter support on the end.
andy
ok let's try this again. i re read your post & it looks like you don't have the 6 cyl starter at all. the correct starter will bolt to the front face of the clutch housing with 3 bolts. it is a close fit to get to the top bolt but it will clear. did you use the old 6 cyl flywheel? if you did it should all match up when you get a starter with the correct nose on it.
andyh1956 is offline   Reply With Quote
Old 06-04-2011, 09:49 PM   #3
CVA59
Re: Starter Problem
Thanks, Yes, i am using everything from the old I6. I will pick up a new I6 starter. Thanks for the input.
Zack
www.23t.weebly.com
Old 06-05-2011, 01:11 AM   #4
Captainfab
60-66 Nut
Re: Starter Problem
If you're still using the original cast iron bellhousing, then you will have to use a starter that bolts to the bellhousing. A block mounted starter will not work.
Old 06-05-2011, 10:33 AM   #5
CVA59
Re: Starter Problem
Thanks Fab. Looks like another of many trips to the parts store is in my near future, LOL.
Zack
www.23t.weebly.com
