06-05-2011, 11:51 AM | #1 |
Building Dreams out of Dimes!
1 JL audio 12 w7 or 3 10" shallow mount pioneers?
Hey guys I have room for either 1 12" JL Audio w7 or 3 10" shallow mount subs? Which should I go with for behind the seat of my '81 single cab Chevy? Which one will have the most boom? Thanks.
Posted via Mobile Device |
06-05-2011, 02:07 PM | #2 |
>130dB Moderator
Re: 1 JL audio 12 w7 or 3 10" shallow mount pioneers?
The W7 will, but behind the seat, there's no way it would ever fit.
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
06-05-2011, 07:31 PM | #3 |
I have bucket seats. The box will.be behind the seats. speaker in the middle.
Posted via Mobile Device Last edited by Hazieview; 06-05-2011 at 07:37 PM. |
06-05-2011, 08:07 PM | #4 |
1 12" JL Audio w7 - 1000 watts nominal. $850
3 12" - Pioneer shallow mounts - 1200 watts nominal. $660 Those are the specs. Does that sound right? Posted via Mobile Device |
06-05-2011, 09:11 PM | #5 |
I guess my first question would be what are your goals? Are you just looking for the loudest system possible, or loud and clear with sound quality?
06-05-2011, 11:30 PM | #6 |
MadMan
the pioneers are nice...
81" Shortbed C10 Full Restoration underway, who needs a budget?? LS Pro Touring Build |
06-06-2011, 02:21 PM | #7 |
Clean and clear sound is what I want! Enough base to impress me over my straight pipes. Not trying to have the loudest stereo in town. Just something that sounds better than average.
06-06-2011, 02:36 PM | #8 |
needs more $$$
Out of the 2, I'd go with the W7. The only thing I'd be worried about is the box design and making sure it's not an eye sore.
1970 2wd Blazer |
06-06-2011, 02:44 PM | #9 | |
I totally agree. While shallow mount subs have their place, they will never perform as well as a standard built sub. The W7 is one loud SOB, but it is a sound quality sub, not an SPL monster. There are speakers out there built with nothing in mind but all out SPL, but generally musically they are not that great. If you can build the box to not look like an afterthought, that W7 would be amazing in the little cab of your truck. Loud, clear, and more than enough bass to hear it over your pipes |
06-07-2011, 10:45 PM | #10 |
So if I can't make the w7 work would the 3 shallow mounts be ok or no?Posted via Mobile Device
06-07-2011, 11:07 PM | #11 |
3 shallow mounts will sound better then average.. so yes they will work. If you are looking for better then average you have alot of options that will fit in a small space.
06-08-2011, 12:22 PM | #12 |
needs more $$$
How do you rate your ability to build a speaker box? Since you are running buckets, I would stay away from the shallows. I have never ran them personally, but my feelings about them are they were made for people with little to no room for subs. With buckets, you could utilize the space behind the seats for volume, but mount the speaker(s) between the seats. If done right, it looks great and should sound much better than shallows.
1970 2wd Blazer |
06-08-2011, 02:01 PM | #13 | |
Any pictures, drawings, suggestions? I want something clean. Something that looks like it was almost put there out of the factory. I'm not big on 'displaying' my speakers for every thief to see. Thanks guys. Let me know if u have any ideas. Posted via Mobile Device |
06-08-2011, 02:52 PM | #14 |
C-10 Club Member
I have played with both speakers.....
What amps are you going to run and how much power are you throwing at the subs/sub? The W7 is hungry and will want 1000 watts. We hooked one up to a honest 600 wattsw and it sounded like crap. I would also like to know what your going to run for your front stage and how much power. A W7 with 1000 watts is going to need a whole lot of mid and high to sound good and honestly I don't know if you can acomplish that in a regular cab. 2 of the pioneer shallow mount 12's matched up with a nice set of components in the doors would sound better than a W7 and nothing special in the doors...imho
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels 1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910 |
06-08-2011, 03:43 PM | #15 |
Here is an idea:
Just move the amps under your seats and use the space behind your seats for box volume, or stack the amps behind the passenger seat and use space behind driver seat for box volume. You can flush mount the woofer and cover in grille cloth to hide it from curious onlookers. Don't worry about how difficult this looks on the outside, a box is a box. Building it won't be too hard (remember geometry class or were you daydreaming about the senior class prom queen?). Its covering your finished product that will try your patience. Mal Last edited by 4ofakind; 06-08-2011 at 03:45 PM. |
06-08-2011, 04:46 PM | #16 |
Another example. A bit more invovled being fiberglass but its an idea. You can still flush mount and cover the subs for security. Mal |
06-09-2011, 09:25 AM | #17 | |
My original thinking was that my components and 6x9s would sound perfect with 2 shallow mount pioneer subs... I really do not want a speaker box in the middle of my seats. I would kind of like it to look stock but sound awesome. It just kind of ads to the surprise when it looks ordinary at first glance. Kind of like when I pop my hood and there isn't an old dusted up 305. Instead its a freshly painted, 450 HP sb400 with shiny aluminum brackets. Haha Posted via Mobile Device |
06-09-2011, 11:02 AM | #18 |
needs more $$$
"I would kind of like it to look stock but sound awesome."
I think that comment right there lets you know which subs to pick. I think you should be able to pull off all 3 shallows with your highs/mids and have a good balance. Now, get to building and take some pics! I'd like to see the 400 too if you got a pic of it...
1970 2wd Blazer |
06-09-2011, 12:26 PM | #19 |
78K & 79C Jimmys
having run subs in mono and stereo
found the amp in mono louder with bridging but preferred hearing the seperate left and right hits
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
06-09-2011, 12:27 PM | #20 |
I appreciate all the feedback guys!!! I found this thread very informative.
I do have one other alternative. What about raising the stock center console of my '81 about 6 inches and 'hiding' the w7 inside of it. If it is possible I could build the box behind the seats and have the speaker come out between the seats. Like the pictures 4ofakind posted. If I could build it right I could just hollow out the console and set it right on top of the speaker. That way it won't look cheesey and it would still look stock. Think it would work? If not I'll just go with the shallow mounts like I orifinally planned. I just like having stuff that is unique... Thanks again guys! Posted via Mobile Device |
06-10-2011, 11:08 AM | #21 | |
Mal Last edited by 4ofakind; 06-10-2011 at 11:09 AM. |
06-10-2011, 12:16 PM | #22 |
needs more $$$
What's an 81 console look like? Is it like the '70 console, but a little different shape? My only concern would be fitting the enclosure inside of it. 4ofakind's are 8" speakers, and the enclosure barely fits between the seats. It makes me think the console just isn't wide enough to fit a 12" W7.
BTW, 4ofakind, looks good!
1970 2wd Blazer |
06-10-2011, 03:56 PM | #23 | |
A trick for you Hazieview would be to turn your woofer backwards and let it bounce off the rear wall like this: Mal Last edited by 4ofakind; 06-10-2011 at 03:57 PM. |
06-11-2011, 01:13 PM | #24 |
06-11-2011, 01:38 PM | #25 | |
I think this is the part I need. http://www.classicpartsusa.com/produ...73_Truck_Parts I could do like 4ofakind said and turn the woofer backwards or slam it towards the floor. Personally I kind of like the backwards idea... Posted via Mobile Device |
