Old 06-05-2011, 05:24 PM   #1
63 Chevy Stepside
Gas tank bracket removal
What is the preferred method to take the old inside gas tank brackets out? I could just cut off the lower portion and leave the spot welded section in, but would rather not. Do I need one of those spot welder drill bits???
Thanks.
63 Chevy Stepside is offline   Reply With Quote
Old 06-05-2011, 05:28 PM   #2
CdM
CdM's Avatar
Re: Gas tank bracket removal
i just cut the nose off and left the bracket. It seems kinda structural to me. If not then drill the spot welds and hammer away. Also i think the one bolt that is left holds the cab support brace. might want to brace that up...good luck
Build Thread 66 custom cab lwb http://67-72chevytrucks.com/vboard/s...d.php?t=465726
66 fleet lwb- In process
64 k10 10inch lift 38.5's- In process
92k1500 400hp on 38.5-parts truck now 8(
CdM is offline   Reply With Quote
Old 06-05-2011, 05:48 PM   #3
MailManX2
MailManX2's Avatar
This is what I did
Removed the excess part of the bracket
Cleaned up and scribed a line in the front part of the bracket
Folded the front part of the bracket up
Welded up and ground down
Ken B
60 Chevy Apache
2019 Chevy Silverado Z71
Why buy something when you can build it for twice the price..
Just because something can be done doesn't mean it should be done...
MailManX2 is offline   Reply With Quote
Old 06-05-2011, 06:33 PM   #4
jgarverick
i cut the spotwelds and removed the whole bracket. go slow so you don't drill all the way through the back of the cab. don't ask...
Jason Garverick
64 C10 SWB Stepside 350/muncie - 5.3 vortec (soon)Thread
69 AMC Javelin 360/auto - 417 stroker (soon)
68 Scout (Basketcase)
06 Ram HEMI SWB Reg Cab Daily Driver
US Army Vet
jgarverick is offline   Reply With Quote
Old 06-05-2011, 06:41 PM   #5
oklahomaduner
oklahomaduner's Avatar
I did something similar to mailman
1966 GMC Extended cab 1 1/4 ton 4x4
My build thread
1958 Chevy 1 ton dually flatbed
My Dad's build thread
1966 GMC Custom Trim Big Back Window W/351e
My Time-Killing Project Truck
1966 (Not So) All Original Chevy Custom Trim Suburban
My Dad's Time-Killing Project Truck
oklahomaduner is offline   Reply With Quote
Old 06-05-2011, 06:46 PM   #6
LeftCoast32
Custom Builder
LeftCoast32's Avatar
We just did this to our Big Window Cab. We used the spot weld tool from Snap-On/Blue Point and it worked great. The trick as I learned was to use a small wood wedge behind the panel. This is to put just enough pressure so that as soon the weld is cut it will pop out. Just take your time as there are about 14 spot welds holding each one in. I only went through the cab on one weld, that is when I figured out the wood wedge trick. If you go through the cab save the plug to weld back in.
LeftCoast32 is offline   Reply With Quote
Old 06-05-2011, 07:26 PM   #7
lakeroadster
I used a cut-off wheel, good enough for my ole shop truck!
lakeroadster is offline   Reply With Quote
Old 06-05-2011, 09:48 PM   #8
63 Chevy Stepside
You Guys are awsome Just what I was thinking, both ways look promising and now I know the tricks to both!
Thanks very much.
