Old 06-06-2011, 02:23 AM   #1
bakerboys
bakerboys's Avatar
headliner mod
Has anyone put a headliner in a truck that did not come with one I got all the parts out of a parts truck and want to put it in my 77 shortbed any ideas thanks
bakerboys is offline   Reply With Quote
Old 06-06-2011, 09:04 AM   #2
zackary027
zackary027's Avatar
Re: headliner mod
same here
zackary027 is offline   Reply With Quote
Old 06-06-2011, 06:37 PM   #3
storked82
storked82's Avatar
Re: headliner mod
Hello Baker
I have put one in my 82 the thing that you need to make sure to use if you are redoing the material is to use high temp glue and im not talking about 3ms'' supper 77 it wount handel the heat it is very easy to put one in I put black vinyl on my and it looks good rember the glue is the thing to rember if your going to put different material on
Take Care
Jeff Main
storked82 is offline   Reply With Quote
Old 06-06-2011, 07:07 PM   #4
rayfinseats
Re: headliner mod
I own an upholstery shop. If you have the board and the moldings it would be pretty easy. I would take it to a shop to have them cover the board or buy a board thats already covered. I would use regular headliner material and not vinyl because although vinyl may hold it usually wont last as long because you have heat baking the roof and the heavy weight of the vinyl fighting to drop it.
rayfinseats is offline   Reply With Quote
Old 06-06-2011, 09:31 PM   #5
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: headliner mod
Put in all the trim first. That way you can mark and drill all the mounting holes that you'll need.
Remove the visors and the interior light assembly.
install the headliner using the visors to hold the front of the headliner and reinstall the dome light assembly to hold up the rear of the head liner.
Reinstall all the trim and you're done.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
