06-06-2011, 05:50 AM | #1 |
Old Heap Driver
I need a measurement
The bolt-in transmission tunnel found in some of our trucks (4X4?)......I need the width, length, and height. My '50 is going to need a trans tunnel and I'm thinking one of the bolt-in tunnels might be a good base to build off of.
Thanks!!
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
06-08-2011, 05:58 AM | #2 |
Old Heap Driver
Re: I need a measurement
Bump
06-08-2011, 04:42 PM | #3 |
15"x 21-3/4"
Height of main body, 5-1/2", at rear 2", at front lip 6-3/4" Front of cover has a radius, rear has a bit of a "notch". If you need more info let me know. |
06-08-2011, 06:43 PM | #4 |
Sorry, I listed the width as 15", 17" is correct.
Working 3rd shift! |
06-08-2011, 06:55 PM | #5 |
Old Heap Driver
Thank you Sir! Measurements and Pictures!
06-09-2011, 09:14 AM | #6 |
the tunnel posted is a 4speed 2wd a 4wd tunnel will have a hole farther back and to the right for the transfer case shifter and the end of the tunnel does not taper off it is the same continued height the whole length
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 |
